I have recently bought 2 Maxtor Diamondmax 10 200GB 7200RPM S-ATA/150 harddrives and have now run into some problems.
The most obvious is that when I watch videofiles they are choppy. They stop for a second and then continue. This happens a couple of times a minute.
Yes I have all the right codecs installed, I have tried several different codecs, uninstalled and reinstalled all codecs and graphic card drives.
I then noticed that the problem only existed on one of the drives and I began to suspect the drives. I tested to
play a video file and also copy files between the drives. I noticed that the transfer speed at the same time as the movie "chopped" dropped to less than 1MB/s!
Then I tried HD Tune, a hardrive benchmark program, and got these results:
This is a benchmark of the problematic disk
This is a benchmark of the second disk that works fine
I have checked so that UDMA is not off, so that's not the problem. I've tested with Powermax, a diagnostic application from Maxtor and it showed no problem. Could it be the S-ATA controller that have problem with the transfer rate? If so, I don't have a clue how I can fix/update S-ATA controller-drives so if you think that's the problem, please explain how to do that
Computer spec.
Pentium 4 3.6GHz
2x 512MB DDR2 533MHz
Motherboard: ASUS P5GD2
2x Maxtor Diamondmax 10 200GB 7200RPM S-ATA/150
Radeon X850XT 256MB
Computer spec.
Pentium 4 3.6GHz
Radeon X850XT 256MB
