Tom's Hardware > Forum > CPU & Components > Sound Cards > What benefits does Audigy 2 7.1 have over onboard sound?
Forum CPU & Components : Sound Cards - What benefits does Audigy 2 7.1 have over onboard sound?
Hi, i plan on getting an audigy 2 7.1 value and was wondering what advantages it has over onbaord sound in terms of sound quality in games and MP3s and framerates in games. Im using Sennheiser HD-570 headphones and i also use small harman-kardon speakers.
Sponsored Links
Quote :
This is the exact card I just got for like $69 bucks and it made my framerates go from 32 to 71 in Half-Life 1 Multiplayer :)
It's better to have a soundcard than onboard so it does it's own processing
Reply to TunaSoda
what about in terms of quality?
Reply to sah
Quote :
Well, it's basically the same card as the $129 gamer version, except that it has plastic jacks instead of gold jacks, no firewire, and it doesn't come with handfulls of games...
I only used it breifly for a game or two, but it's much better than my onboard was!
I used it with two stereo speakers last night, but tonight I am going to try it out with my 7.1 setup :)
We will see...
Reply to TunaSoda
Does anyone know how it will affect headphone users? Will high quality headphones sound differently on an Audigy compared to onboard sound.
Reply to sah
Yes, but if you are running high quality headphones the difference between those two wouldn't be as big as getting an external amp.
Reply to astrallite
Headphones? Probably not as "modern" onboard sound controllers do have decent headphone jacks. A separate soundcard benifits as it has separate processing (mentioned before) meaning more processor usage for other tasks. Usually the quality is better for sound cards as well. Please note that on most systems you will want to disable onboard sound in your BIOS BEFORE installing the sound card. XP *should* work even with both enabled, but trust me, save yourself the potential trouble and disable it in the bios.
Reply to bourgeoisdude
There are 1237 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
