Fortron Problem...
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Fortron Problem...
Ok i took someone's advice here and bought this FSP psu... and it blows... http://www.newegg.com/Product/Prod [...] 6817104953
for some reason the 3.3V line is VERY weak... delivering 3.08 at load and 3.2 at idle... and i have experienced SERIOUS lag in COD2 that i never experienced before with my old generic JUSTPC 425 watt oddly enough... only when i underclocked my gpu by like 50mhz and brought my cpu to stock speeds it would work fine... so i returned the psu and just put my old psu back in and everything works now- gpu oc by like 50 mhz and cpu oc by like .15Ghz... yea so FSP blows... but anyone reccomend another psu as i still want to replace mine???
Sponsored Links
I'd send it in for warranty replacement, or return it to newegg if it's within 30 days. Fortron fsp makes power supplies under several labels, and they should be able to help you. The best warranty response I received was from enlight. They actually returned my call and I got to talk to a real person.
Reply to o1die
You send one that's mis-adjusted back, they send you another one. Then you don't need something else.
Reply to Crashman
- 0 +
This one is supposed to be good, which I'm planning to get myself:
http://www.newegg.com/Product/Prod [...] 6817104954
Given the good reviews of the 400 that you got, I'd say it's defective. Fortron is supposed to be a popular brand.
Reply to theslug
- 0 +
Off topic...What's your take on the importance of PFC when purchasing a PSU?
Reply to Rugger
It helps keep the power lines clean for your power company. Do you like your power company?
Reply to Crashman
- 0 +
That's the impression that I was getting - is there any other benefit?
...bastages recently jacked the rates by over 20% so I'm not on good terms with them at this moment. :evil:
Reply to Rugger
Er, it reduces the efficiency of your power supply slightly, so your electric company can be more profitable?
Reply to Crashman
The Enermax noisetakers at 480w and 660 watt are what toms said has the cleanest power of the power supplies that they have tested. I have one and love it. It is also quieter than any previous psu i have had.
Reply to baracuda73
OK then, tell them to send me one.
Reply to Crashman
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Fortron Problem...
There are 1091 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
