I recently bought a 512 stick of ram off newegg and when I installed it booted up my comp I would just get a blank screen. Which I know it means it could be installed improperly or its the wrong ram. The thing is its the same type of ram thats already installed in my computer which is another 512mb stick.
My computer is a compaq (I know bad choice) and i did some reseach on it. Found out the mobo is a ASUS (K8N8X-LA PES) and it takes Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB). link http://h10025.www1.hp.com/ewfrf/wc/genericDocument?cc=us&docname=c00064822&lc=en
The ram that I bought is gigaram 512MB 184-Pin DDR SDRAM. Link http://www.newegg.com/Product/Product.asp?Item=N82E16820221005
So this really annoyed me I downloaded cpuz to see what ram i was already running. Which was Samsung DDR-SDRAM PC3200 - 512 MBytes.
The max ram my mobo can take is 1GB.
So I thought if I updated the BIOS and chipset drivers it could work which it didnt. Also I looked around and read that compaq's mobos are picky with ram which could be the reason and there bios sucks since there bascially isnt one. So I know I could just return this ram but first I want to find out why it isnt working in the first place. Or I was wondering if I could just spend 50 dollars a new mobo and if the memory would work since it isnt running on a compaq mobo or bios. So thanks in advance and sry if this is a bit lengthy.
