Centurion 531 + Which Power Supply???
I was considering buying the Centurion 531 w/ power supply included ...
but I have just read that the eVGA Geforce needs a 450 watt PSU so I am thinking of buying the case without the PSU and getting a separate one.
Here are the specs of the system that I am thinking of building
eVGA 133-K8-NF41 Socket 939 NVIDIA nForce4 SLI ATX
eVGA 256-P2-N518 Geforce 7800GT 256MB GDDR3 PCI Express x16
AMD Athlon 64 3200+ Venice 1GHz FSB 512KB L2 Cache Socket 939
Patriot Signature Series 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit
I have normal ATA hard drives and a PCI sound card (Hercules Game Theater XP) that I will be running for a while until I get around to upgrading them
What PSU would you suggest for this build? I don't plan on overclocking ...
4 answers Last reply
More about centurion power supply
  1. Enermax has a nice one. it's called the Liberty series. there good PSU's.
    I have 2 620W running in my super machine of death. i like the efficantcy ratting too.
    I would say 500W would be fine but to be safe 620W
    http://www.newegg.com/Product/ProductList.asp?Submit=Go&DEPA=0&type=&description=enermax+liberty&Category=0&minPrice=&maxPrice=&Go.x=0&Go.y=0
  2. Enermax PSUs very good. If you need a slightly less expensive alternative, try http://www.newegg.com/Product/Product.asp?Item=N82E16817104014. It's very good and I think you'd be more than satisfied. It's a Fortron, and they have performed very well for us over the years, as have Enermax.
  3. Your system should run on any good quality 450W power supply. I'd go for 500-600W depending on how many things you might add later.
  4. ah, save some money and get a good quality 500W, that will support two of your video cards in your system, which is probably the highest load the thing will use.
Power Supplies Centurion Components Product
