help... to overclock or not ?
binner
16
I have a Soltek QBIC 3401. This is a small form factor box.
I am upgrading my Graphics card and I have narrowed it down to X800GTO or GF6800GS.
I only have an AGP slot. (currently running 9600XT)
How much would the heat load increase by if I bought the X800GTO and flashed it to get 16 pipes ?
Does the fact thatI have an SFF box mean I should just go with the 6800GS and forget overclocking ?
The PC currently has 2 HDD which I am changing for 1 larger , (and hopefully quieter and cooler) which will reduce heat load.
Power supply is rated at 250W will this cause a problem ?
Human1
306
Wouldn't mind being in your position. Hmm...which new graphics card do I want?
Yeah, that's a pretty tiny PSU to be running a graphics card like that. In order to be stable you'll probably want to up the juice available. Lower wattage PSU's also tend to carry less amperage which is bad for power hungry components.
As for your overclocking question, why do you want to OC? I mean, yeah it sounds cool, but is a 6% increase in performance really going to help you out? Espcially in a SFF case, where airflow can be a problem, go with Nvidia. In my experience they run cooler. Unless you have the water cooling...
raven_87
1,756
The X800 line consumes a bit less wattage and disipates a little less heat then the 6800 line...hense the need for a smaller HS/F.
Overclocking a SFF PC is useless...that I'll agree. Airflow is tight enough as is.
EDIT: Almost forgot...250watt PSU, that could be sticky situation your in.
Could you post the rest of your system specs please? - That would really help.
cleeve
Illustrious
You can't flash an X800 GTO to 16 pipes.
You can flash an X800 GTO2, and the X800 GTO 16 comes with 16 pipes enabled from the factory. But I haven't heard of a successful X800 GTO unlock yet.
Your power supply is too wimpy for sure. And overclocking is not a good idea for that form factor... but you can still get good performance.
binner
16
I think I am confused. When I said "overclocking" I was referring to flashing the 12 pipe card to 16 pipes, a case of incorrect terminology apologies.
I thought the X800GTO could be unlocked/flashed (delete as applicable) to 16 pipes it just ran the 420 core not the 480
Does the GF6800GS come with VIVO ?
Do any of these US sites with fantastic pricing ship to the UK ?
Supposedly the Sapphire, Connect3D and GeXcube cards are highly modable, although there was a statement about the Connect3Ds no longer being as modable.
Not quite the GTO2 level, but very high success rates have been reported, higher than the X800Pro mods (which were primarily ViVo confined).
Alot of people are saying R480 core on AGP cards (I think that's what GW's is saying), but wouldn't that be R481 if there isn't the presence of a Rialto bridge?
binner
16
for completeness
cpu = P4 3.0GHz (Northwood)
RAM = 1GB (2 x 512)
Chipset = intel 865G
1 agp and 1 PCI expansion ports
2 HDD 1 x 40GB 1 x 140GB both IDE not SATA
Mobo is SATA capabale
Curent GPU Radeon 9600XT
PSU= 250W
BIOS = AMI
Not sure if I can get a power supply with more punch that will fit in the case
I am also considering X800XL and X800XT (though I think the latter requires 300-350W power supply)
If possible I want to connect my PS2 to the card to allow me to use my TFT to play GT4 on.
I I spend no more than £150 on the card then I can also buy a box to connect the PS2 directly to the monitor
the more I think about this the more confused I get
BTW games played are BF2 and CS:Source / HL2
At the moment , baed on what I can find on UK sites to buy now, this is looking like the best bet
http://www.overclockers.co.uk/acatalog/6800_Series.html
raven_87
1,756
No new GPU without a new power supply: that would be suicide.
Both the X800XL and XT require a 350watt PSU, I would look to the XL
on consuming less wattage though.
Thank god you dont have a Prescott, that alone with your machine should have been enough to destroy that PSU.
binner
16
so because the power supply is only 250W I can only realy go for
X800GTP (AGP) or
GF6800GS (AGP)
Or do I need more power for these as well ?
If I need more power does anyone know of a good PSU that will fit in my case ??
binner
16
well we all make mistakes.
At the time portability was high on the list of priorities and I specced the system to last 3 years.
Probably a bit short sighted on the GPU and power requirements but hey.
so any thoughts on the X800GTO vs GF6800GS and power then ?
raven_87
1,756
Might be...
Then again he could overload his PSU beyond bootup = death
Hopefully only taking the new GPU with it.
EDIT: @ Crashman... "Bought a Dell" .....LOL...yea, that would have been much much better **insert sarcasm here** Actually, might save him SOME hassle, my collision course with Dell wasnt a pretty one, kinda why I had too laugh and shudder at the same time.
binner
16
thanks for all the help
very useful
ta
the PSU is Soltek model number ENP-2725d
I have had a recommendation to look for a Seasonic Micro ATX PSU. A standard size one will not fit in the case.
GeneticWeapon
Splendid
Jan 13, 2003
5,795
My card has the rialto bridge, it's the big chip next to the AGP slot.
Crashman
Polypheme
Former Staff
There are several standards for smaller power supplies, the most common being SFX, and the most common for even smaller systems probably being TFX.
There is no such thing as a "Micro ATX" power supply, a bunch of different sizes are listed by venders as "Micro ATX" because venders don't know form factors or expect their customers to know them.
binner
16
yes
I have seen that from looking around.
I will have to check the dimensions as well as the rating
useful (but dry) web site
http://www.formfactors.org/
Crashman
Polypheme
Former Staff
I didn't see anything about PS/3, which was SUPPOSED to be THE Micro ATX power supply before SFX was introduced. PS/3 has the same mounting surface as the full-sized PS/2 power supply, but a reduced depth.
RichPLS
Champion
Hmm, my HiS X1800XT does not seem to have a larch chip anywhere on the back of the card, top as it is installed...
So this makes it a R481 rather than a 480?
Is this somehow improved then?
binner
16
these look like they will fit
click HERE
Just heard back from XFX apparently for the GF6800GS AGP they recommend
wait for it
450 watt power supply !!!!!!!
can I get away with 320 ?
The power load calculators on the power forum come back with 280 and 312 watts using GF6800GT cos they don't have the GS on there
GeneticWeapon
Splendid
Jan 13, 2003
5,795
You have a PCIE motherboard......your gfx card doesnt need a chip that converts pcie to agp :idea:
