Hey guys i have a pentium 2.8E Prescott CPU that goes CRAZY when i dl music or play games like Counter Strike or Warcraft 3.
It even gets soooo loud and when i just play music videos!
My Computer setup is this, Asus p4p800SE, with 512mb samsung RAM, 1 LG DVD drive, 1 Liteon Cd writer, 2 harddrives (80Gb Maxtor IDE and 15 GB Maxtor IDE), 2 case fans: one stock one and a thermaltake smart fan 2 set on lowest speed with remote. Most importantly, my PSU is a thermaltake Purepower 420 Watt.
My room is soo well insulated do to two years ago with renovation, and so it insulates air inside extremely well.
I DO NOT HAVE AIR CONDITIONING for the summer, just a window fan, and where i live in Toronto Ontario summer temperature gets up to 35 to sometimes 40 degrees Celsius!
It feels like its even warmer inside my room because of the insulation and i have a feeling the computer generates a lot of the heat in the room because my other rooms are not as hot as the computer room once it is turned on!
I am using the stock Intel fan, and it gets SOOOO LOUD IT DRIVES ME NUTS WHEN I DOING HW!
I have decided to get a cpu fan because i probabily won't be upgrading my cpu anytime soon, maybe in 4-5 years.
Can anybody recommend me a cpu cooler that would do the job and it HAS TO HAS TO HAS... BE VERY QUIET!!! something under 20dB would be nice!
I have narrowed down to:
Zalman CNPS7000B-AlCU CPU Heatsink/Fan
Zalman CNPS7000B-CU Copper CPU Heatsink/Fan
both of these i dunno whether if i should invest in the copper one if the temperature would be that great of a difference, but the sad fact is that these two do not support silent mode for intel Prescott models! Also i measured the centre of my cpu to my PSU, and there is only .5 of a cm clearence =/
The 7700 Series does not either, because my cpu tower is not sooo big, its about medium size and i measured it and the PSU would obstruct it from installing it!
A few more i have thought of are:
Arctic Cooling Freezer 4 CPU Heatsink/Fan - ACFZ4 (S478)
http://www.arctic-cooling.com/cpu2.php?idx=9&data=1&disc=
Arctic Super Silent 4 Ultra TC
http://www.arctic-cooling.com/cpu2.php?idx=22&disc=
Arctic Cooling Super Silent 4 Ultra CPU Heatsink/Fan - ACSS4U (S478)
http://www.arctic-cooling.com/cpu2.php?idx=23&disc=
Arctic Cooling Super Silent 4 Ultra TC CPU Heatsink/Fan (S478)
Arctic Cooling Super Silent 4 Ultra TC L Heatsink/Fan (S478)
The last four i don't even really know what is different about them, but they are nice and small and they claim to be very quiet, but i don't know exactly how loud 1 sone and .5 sone is in decibels to compare with the Zalman's.
I also like the:
Thermaltake CL-P0114 Big Typhoon 4 in 1 Heatpipe Cooling For LGA 775/K7/K8
http://www.thermaltake.com/coolers/4in1heatpipe/cl-p0114bigtyphoon/cl-p0114.htm
but im afraid it will not fit onto my CPu due to my PSU, and i read reviews that its really difficult and a hassle to install it in! But i like it cause its only like 16dB and rarely over 20dB!! Wow!
I might use this cooler in the future, maybe once i switch to and AMD and i might do some overclocking.
I was also thinking of fanless cpu coolers by thermaltake the p0019 fanless, but im afraid it will get my room even hotter or it will overheat the cpu because how hot my room is! =(
http://www.thermaltake.com/coolers/cl-p0019Fanless103/cl-p0019fanless103.htm
So please guys help out a friend who's very hot in his room in the summertime and the noise is driving him insane! Im sure you guys know how loud and hot prescotts can be!
