Tom's Hardware > Forum > CPU & Components > CPUs > CPU Fan Problems...
Hey guys,
I'm new to this forum. When I boot up my system, I'm getting an error message saying "Warning: Your computer CPU fan fail or speed too low."
Does anyone have any ideas? I know I can disable the warning, but is there a way for me to adjust the CPU fan speed?
Thanks,
Sponsored Links
The problem is probably this: you have the CPU fan plugged into the wrong connector or you have a cheap aftermarket CPU fan.
If you are using the heatsink/fan that came w/ the processor then you're fine. My A8N-SLI does the same thing. Don't worry about. Disable the warning message.
If you really really really want to be sure nothing's wrong, run Ai Booster (you should have installed it, if not it's on the Asus mobo CD) and check ur CPU temp. It should be at/around or below 45C for that processor. Assuming you have a decent case w/ decent airflow... You can also check the CPU temp in the BIOS.
-mpjesse
Reply to mpjesse
Okay...I'll just disable the warning. I'm pretty sure it's in the right connector on the mobo though...it's in the CPU_FAN connector. Thanks for your help!
Reply to ShadowVulcan
Quote :
If you've got fan speed control set/cool and quiet or similar then that's probably the cause.
The BIOS is probably set to only turn on the CPU fan above (say) 20 degrees .. when you turn on the PC the CPU is cool so the fan is off and it triggers the alarm. The CPU quickly heats up so the fan starts... It's probably not a problem.
Reply to bboysil
Damn, thanks - thats really handy info bboysil; very logical actually.
Ive swapped out my cpu fan twice now and was starting to believe I had power supply dispersion problems with my motherboard!!
Reply to DannyBoy27
There are 1220 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
