I recently bought dual channel memory. before the upgrade i was using a single module pc2700 256mb of ram installed in slot 2.
I'm having problems running dual channel on my mobo, my system wouldn't post when i follow the dual channel config(slot 2 & 4). The memory would only run in single channel mode( memory installed in slot 1 & 2).
System setup
MSI K8T neo2-F(bios 1/10/2005)
athlon 64 3000+ venice
1 GB geil value ram - dual channel ddr 400
These are the memory combinations i tried:
Slot 1 & 3 - didn't work
Slot 2 & 4 - didn't work
Slot 1 & 2 - works but only in single channel mode ddr 333 1024MB
Slot 3 & 4 - didn't work
I also tried putting one module at a time in slot 2 and it works, i think the modules does not have any problems.
I need HELP!!!! I didn't buy this memory just to let it run in single channel mode.
Do i need to change my bios or my board?
System setup
