Problem printing website frame in TS.
Anonymous
Archived from groups: alt.swnet.comp.lang.javascript,microsoft.public.windowsnt.terminalserver.applications,microsoft.public.windowsnt.terminalserver.misc (More info?)
We run into a strange problem with a client when printing a frame from a
website. On the site there is a button that performs the following
javascript code:
parent.myFrame.focus();
window.print();
This is the normal way to print a specific frame from a website. Our client
works on a SBS2003 with Terminal Server and when they hit the button all
frames are printed out, not just the selected one. At first I thought that
the print option 'all frames seperately' was selected, but that wasn't the
case. The right option ('only the selected frame') was selected.
So it looks like the focus() method does not work. I tried the same website
on another Terminal Server and that worked perfect. So I guess it has
something to do with that specific Terminal Server. But I can't figure out
what?!
Also searched on the internet and newsgroups, but unfortunately I can't find
a similar problem description.
Anyone ideas how to solve this problem??
Thanks in advance for answering.
Richard
javascript code:
window.print();
what?!
Richard
answer
Last reply
More about problem printing website frame
FYI:
I solved the problem by using the ScriptX plugin from MeadCo
(http://www.meadroid.com/scriptx/index.asp). The free part of this plugin
was enough for me to solve the problem.
Richard
"Richard Brand" <rbrand@nospam.itannex.com> schreef in bericht
news:36c7b$42305408$c355934c$4565@news.essentkabel.com...
> javascript code:
> window.print();
> client works on a SBS2003 with Terminal Server and when they hit the
> button all frames are printed out, not just the selected one. At first I
> thought that the print option 'all frames seperately' was selected, but
> that wasn't the case. The right option ('only the selected frame') was
> selected.
> website on another Terminal Server and that worked perfect. So I guess it
> has something to do with that specific Terminal Server. But I can't figure
> out what?!
> find a similar problem description.
> Richard
Javascript
Microsoft
Terminal Server
Windows
Related Resources
- Website loading problem
- Problem getting to website address
- Javascript problem
- Problem loading only one website
- Cannot access company website
- Folder Redirect issues over Frame Relay
- Problems
- Best way to boot / connect to terminal server from client
- Connecting to website secure area fails - Passport problem?
- WINDOWS 8 64 HZ FRAME CAP!!!!!!!!
- Website advice
- Change Microsoft Support Website Language
- Javascript
- DVD Express Player -- frame-by-frame control?
- Can't access Microsoft Newsgroups from Microsoft Website
- Problems with frames in explorer.
- Frame Rate loss from SP2?
- Is Javascript Enabled already?
