Ok im not exactly a newbie I have built a few systems but the lasst one was still a few years back it was a Pentium 3 1ghz system whichis my current family computer. Its done its job well for the past few years and I never had a probblem with it, but its getting old and a bit slow and I just feel its time for something new.
Ok so the computer will be used for very basic stuff, web browsing, downloading music/movies/software, watching the occasional dvd, ripping/burning music and some word processing. No gaming at all so I dont need anything to highend but I would like something thats fast and reliable. I already have a large 250gig HD for storage and I have my music library on that drive so I am all set for storage so a small fast drive would be best and I also will need a Dvd/CDr/w drive and a card reader and thats about all I need, a very basic setup and the budget is around $800 for just the computer I have a monitor, mouse, keyboard....etc already.
So I have a few basic questions i need answered and would really appreciate everyones ideas and opinions.
1. CPU- Intel or AMD?? Entry level dual core(amd64x2 3800) or higher end single core(amd64 4000)?? Or is that to much processor for what I will be using the computer for?? If so whats the best bang for the buck??
2. RAM- How much?? Does dual channel make a significant differance? Any reason to go with high permformance like OCZ Platinum vs OCZ Value memory?? Does it effect performance if your not overclocking?
3. What motherboard and chipset?? Do differant chipsets difer in performance?
4. Hard Drive- since I already have a large 250gig HD for storage, should I go with one of the small but super fast drives like the WD Raptor 37gig?
5. Video Card-I just need the basics, whats a good inexpensive card?
6. DVD/CDr/w-I am a music lover so the cd-rom will get alot of use, ripping and burning, whats a good quality drive that will last?
7. Power supply- do I need a high performance supply or is the basic $25 400w supply good enough for my needs?
Ok I think thats basically all I need to know. Just need some advice on what would be a good system for what ill be using the computer for. Obviously I want as much speed and power as I can get for my budget. Any other advice opinions or ideas would be greatly appreciated. Thanks in advance everyone
Frankie
Frankie
