help: pc starts immediately when AVR is turned on
hello, I have a bit of a problem with my pc. My pc starts up when I turn on the AVR, then shuts down a split second later, and I haven't even pressed the 'on' button on the case yet.
I'm not sure what's causing the problem. Could it have something to do with how the motherboard is connected to the case?
The 'on' button on the case looks fine. It isn't stuck or anything.
2 answers Last reply
More about help starts immediately turned
  1. I have no idea for sure, but here's a few wild guesses of things that could cause similar issues...
    First (ok before first, though I'm writing this last - don't ask, I guess i'm conversationally dyslexic or something :lol: ), I'm assuming that you can turn the PC on and off normally, is that correct? If not then let me know and I'll put out new ideas.
    First what is an AVR? My first thought was the switch on the back of PSUs but then I thought maybe a piece of Audio/visual equipment, then just figured I must be stupid so I'll ask :) ...
    Anyways, on to some WAGs:
    Wake on Lan or wake on USB something or other setting in BIOS for a device like a recorder
    Last power state setting in BIOS for an external (to the motherboard) power switch.
    Mike.
  2. AVR: automatic voltage regulator :)
Power Supplies Cases Motherboards Components
