Has any one ever heard of minum spec's.
Incase the red doesnt come across you need more RAM 256 is not enough 512 the minimum you can go with.
Bumping up my graphics all the way for COD2 creates a problem...just before i enter the battlefield or mission, my moniter shuts down, and when i pressed the moniter menu button... it tells me a saving power like msg in a lil box... the only way to get out of that is shut down manually. Is it a psu probelm or ram or what!?!? please help, thanks
_________________
Pentium 4
2.53GHZ Processor
256 MB PC1066 RDRAM
120GB 7200RPM
16x DVD Rom drive
48x CD burner
ATI Radeon 9550 AGP 256mb 128 bit
Harmon Kardon speakers w/ subwoofer
Windows XP...
Call of Duty 2 System Requirements
Minimum Requirements
1, 4 GHz Prozessor (Celeron / Duron)
512 MB RAM
ATi Radeon 9200 / GeForce 4
Optimum Requirements
2, 5 GHz Prozessor (Athlon XP / Pentium 4)
1 GB RAM
ATi Radeon 9800XT / GeForce FX 5900
Battlefield 2 System Requirements
CPU
Battlefield 2 supports the following processors:
Intel Pentium 4
Intel Xeon
Intel Pentium Extreme Edition
Intel Celeron D
AMD Athlon XP
AMD Athlon 64
AMD Athlon 64-FX
AMD Sempron processor
Minimum Specification:
CPU: 1.7 Ghz
RAM: 512 Mb
Video Card: NVidia GeForce FX 5700, ATI Radeon 8500 or ATI Radeon 9500
with 128 Mb of RAM
Recommended Specification:
CPU: 2.4 Ghz
RAM: 1 Gb
Video Card with at least 256 Mb of RAM
