Archived from groups: microsoft.public.win2000.termserv.clients,microsoft.public.windows.terminal_services,microsoft.public.windowsnt.terminalserver.applications,microsoft.public.windowsnt.terminalserver.client,microsoft.public.windowsnt.terminalserver.misc (
More info?)
Yes, that's frustrating.
The web document is more recent, from August 2005, while the Citrix
document is from February 2005.
They must have changed it between these. This particular entry is
the only one that says: Supported: "No", and still lists a driver
version.
All other unsupported models say: Supported: "Not supported" and
list "N/A" under "Driver version". Seems like a quick and sloppy
change.
I don't know if you can get better results with another driver.
_________________________________________________________
Vera Noest
MCSE, CCEA, Microsoft MVP - Terminal Server
TS troubleshooting:
http://ts.veranoest.net
___ please respond in newsgroup, NOT by private email ___
"ThomasTran" <ThomasTran@nospam.nospam> wrote on 28 sep 2005 in
microsoft.public.win2000.termserv.clients:
> Thanks Vera,
> Is there any workaround like changing a generic driver ? Our
> client has a lot of this modele,
> it's not easy to tell them to change the whole batch . Other
> applications work fine, only one
> that prints with small font
> I have seen the document, and i'm crazying when seeing another
> document linked from your website
> that points to Citrix website, in this document it says YES
http://knowledgebase.citrix.com/kb/entry.jspa?externalID=CTX10235
> 6
> "Vera Noest [MVP]" <vera.noest@remove-this.hem.utfors.se> wrote
> in message
> news:Xns96DFDDC82F36Bveranoesthemutforsse@207.46.248.16...
>> The HP LJ 1012 is not supported at all under TS.
>> Documented here:
>> HP Color LaserJet, LaserJet, All-in-One, and Multi-Function
>> Series Products - HP Printers Supported in Citrix MetaFrame
>> Presentation and Terminal Server Environments
>> http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?
>> objectID=c00213455
>> Vera Noest
>> TS troubleshooting:
>> > Hello everybody,
>> > We have a client using TS on Win2K . They have a batch of HP
>> > LJ1012 printers . In some applications developped with
>> > PowerBuilder, some reports printed out with an abnormal very
>> > small font . I would like to know your suggestion where to
>> > check for this problem ? Is there any generic driver that can
>> > fix this ?
>> > Thanks a lot
>> > Thomas T.
