ok, this is the problem, today my c just switched off and now when i try to restart it the PC the Moniters power light omes on (yello) but it does not Turn green.
the pc seems fine to.
This happend 2 year efore to the same type of miniter i had, its a 15" tft.
is the problem with my 9800 graphics card or the moniter?
thanks.
zaburba is right.
sylvez is also right. now let's try some basics..
unplug you video card. get a rubber eraser and erase the contact points of the card. clean the dirts.be careful.
Funny same thing happened to me day before yesterday !
have a Asus GF-4 ti4400 (ancient) on a equally ancient Soyo P4S dragon
changed out the hsf with the vantec iceburg hsf
,then my lcd 19" fujitsu panel things began to get a little quirky then it gradually got worse and then flashing green light ,no image at all through my dvi interface ,thought it was t5he the vid card,at first then after switching it around with my other boxes ,I isolated the problem to my beloved no name Fujitsu panel's dvi input! I would have rathathered Fried my GF-4 instead!!!!
after sweating it,for 2 days applying as3,and ceramique to the gf4 (wasted a bunch of it) last ditch effort to trouble shoot I cleaned the DVI cable and GUESS WHAT? It WORKED ! this was just a few hours ago!Whew
