Tom's Hardware > Forum > Overclocking > Graphics Cards > Geforce Fx5200 Overclocking HELP!!!
Forum Overclocking : Graphics Cards - Geforce Fx5200 Overclocking HELP!!!
I have a Geforce Fx 5200 and i want to overclock it jus for kicks, does anyone know exactly how far i can push the temperature up before it burns? it runs PainKiller on regular settings at around 70 degrees Celsius, is it possible to overclock any further without any other cooling devices, and if so, about how much could i push it up? It runs at 250 on the core speed and 400 on memory clock, help me out please.
Sponsored Links
I am sorry If I disappointed you ...but those old models of graphic cards weren't optimized for overclocking ....
you can hardly at 20MhZ to your core ...and 40MHZ to your memory ...even though I can't guarantee your card stabillity at all ....
above all you won't see any major difference for overclocking ...
Reply to Hameedo
Sorry to be the bearer of bad news, but it's a pointless undertaking. The card's base performance is bad enough that overclocking isn't going to achieve anything noticable.
But, to answer the question anyway, you'll start getting artifacts when you push it too far. Some may be due to heat, and some to just pushing the hardware beyond what it can do. The bottom line is, if it looks fine, then try pushing a little more, and testing again, and repeat. Same for overclocking anything - small increments until you hit problems.
If you're concerned about temps, you could fit an aftermarket cooling solution, but as I said above it really is a waste of time on that card.
Reply to ChipDeath
I'm not too sure about that. I have the same card and I've managed a fair bit of overclock. I just took a regular fan i had laying around, probably costs about 5$ and screwed it on to the heatsink (the holes lined up perfectly, so the screws went into the heatsink slots and held it on) it hangs over one end a bit but it works really well.
I've managed to push mine up to 318MHz core, and 492MHz memory. It is stable and doesnt produce any artifacts at these speeds. Mind you, it still isnt going to be a super card, but hey, i squeezed a bit of extra speed, and it was a blast to do.
Reply to kcaverly
70c degs shit thats pretty damn hot, if you really want to oc go look for a volt mod guide:D i dont know but the 5200Ultra acctually had alright performance some of the time, hmm i wonder if they just put way faster memory on it? dunno, owell. Good Luck.
Reply to TenaciousleyDead
hey i know this is an old thread but if anyones still reading it here's my overclocking results just for interest.
Albatron (i think) FX5200:
319 on the core
539 on the memory
stable, only artifacts occasionally due to bad case airflow, if i put a fan on the HS i bet i could get a little more.
cheap card, bad performer. thank goodness we've seen the end of it.
Reply to hashv2f16
May be old topic,but i was too dumb before i saw this
Im really dumb,i overclocked the graphic card,ALOT,i use FX5200(same as here)(Nvidia),but 1 thing is kinda funny,computer runs great on Windows 7,nothing wrong,also works fine on XP SafeMode,but on Normal XP mode,some green markings come all over and the display goes black or starts flashing
Is there a way to undo that overclock(hopes so)
Reply to Anonymous
sorry i posted soooo late but i am thnking about overclocking my nvidea geforce fx 5200 and i run win 7 on 512mb of ram 86x of corse
Reply to Anonymous
yeah well, i oced pny geforce fx 5200 and i died at only 210 MHz GPU and 420 MHz ram
Reply to sectorzam
There are 764 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
