I am a noob at the hardware side of things and I was wondering if anyone could give me some advice.
I work in a Cyber Cafe and we keep all our systems underneath Desks inside a cupboard type enclosure. There are wee Vents ontop of the desks to let the heat escape but I feel this isnt enuf.
I am gonna fit fans to these holes that are ontop of the desks to suck the warm air out, but wat about the pcs themselfs? Should I set up fans on the case to constantly Blow the warm air out of the case? Will it keep inside the case cooler, or do I need fans to be sucking cold air in aswell? If so, then this is a problem as underneath the desks are always full of warm air so there is no way for the pc to get access to cold air.
I was sorta hoping that if there was enuf fans sucking the warm air out of the case and then the fans sucking the warm air out from underneath the desk that it would keep the PCs cool enuf... but before getting the stuff needed to do this I was wondering if this would work?
Any help would be appreciated!
