System restore doesn't work
Archived from groups: microsoft.public.windowsxp.basics (More info?)
I cannot get the system restore function to restore to any
restore point I've tried. It goes through all the motions
and then when it reboots I get the message "your computer
cannot be restored to [any date I chose] restore point",
or something very similar.
Can anyone offer any advice please? I run NAV and so that
problem should not be a virus.
I don't know what I should do about this, as I have found
the system restore very useful. As my graphics card
driver appears to be corrupted now it would be good to be
able to restore it to a time it wasn't corrupted, instead
I have to go through a load of rigmarole to reintall it
(if I can even find it!). Any advice would be great.
Thanks,
pammi
6 answers Last reply
More about system restore doesn work
  1. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hi Pammi,
    You'll have to go through the rigamaroll to reinstall the card driver.
    Once System Restore goes bad, the only thing you can do is stop it and
    restart it. Start/run services.msc, locate the SR service and doubleclick
    it. Click the stop button, then set the startup type dropdown to disabled.
    Click apply/ok, then reboot.
    Then, check the "System Volume Information folder" on each drive (you may
    need to set folder options/view tab to see hidden and system folders for
    this) and delete any contents. Reverse the steps to restart it.
    Be forewarned that doing this removes all existing restore points, but it
    doesn't really matter as they weren't working anyways.
    If this does not help, follow these steps to reinstall System Restore:
    Go to the Control Panel/Folder Options/View tab, set it to "Show hidden
    files and folders" and "Show the contents of system folders", then uncheck
    "Hide protected operating system files [recommended]". Also uncheck "Hide
    extensions for known file types".
    Then, open Windows Explorer from Start/All Programs and go to the
    C:\Windows\Inf folder. Locate the sr.inf file, right-click it and choose
    install.
    You may need to either insert your WinXP CD or know where your I386 folder
    is located on the hard drive. You may also need to know where the
    \ServicePackFiles folder is (usually under the Windows directory).
    Best of Luck,
    Rick Rogers, aka "Nutcase" - Microsoft MVP
    http://mvp.support.microsoft.com/
    Associate Expert - WindowsXP Expert Zone
    www.microsoft.com/windowsxp/expertzone
    Windows help - www.rickrogers.org
    "pammi" <pammi_i@hotmail.com> wrote in message
    news:8e8501c485ce$51fc6870$a401280a@phx.gbl...
    > Thanks,
    > pammi
  2. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Rick,
    Thanks for this, it is a pretty comprehensive reply!
    Hopefully I'll be able to follow the instructions when I
    return to the offending PC later. Everything seems to be
    working, except for the graphics and the system restore,
    so it should be fine.
    One thing though, you mention the WinXP CD - I only have
    the factory reset CD as the machine came with XP installed
    by the manufacturer. Will that do as well as the full
    version CD if I need it? If not, whih files am I likely
    to need off it please? I am afraid that as soon as I put
    that in the drive I will lose everything (but am backing
    up all my data, email and setup files just in case I have
    to do that anyway!).
    I don't see a problem with locating the folders, as the
    search still works okay.
    Thanks for your help,
    pammi
    >-----Original Message-----
    >Hi Pammi,
    card driver.
    is stop it and
    and doubleclick
    each drive (you may
    system folders for
    restart it.
    System Restore:
    to "Show hidden
    Also uncheck "Hide
    go to the
    click it and choose
    >install.
    your I386 folder
    where the
    directory).
    >Best of Luck,
    any
    motions
    computer
    that
    found
    be
    instead
    >> Thanks,
    >> pammi
  3. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hi Pammi,
    In most cases with the preinstalled machines you use the I386 folder on the
    hard drive, not the CD.
    Best of Luck,
    news:8fb201c485e5$6fb4c760$a401280a@phx.gbl...
    > Rick,
    > pammi
    >>Hi Pammi,
    > card driver.
    > is stop it and
    > and doubleclick
    > each drive (you may
    > system folders for
    > restart it.
    > System Restore:
    > to "Show hidden
    > Also uncheck "Hide
    > go to the
    > click it and choose
    >>install.
    > your I386 folder
    > where the
    > directory).
    >>Best of Luck,
    > any
    > motions
    > computer
    > that
    > found
    > be
    > instead
    >>> Thanks,
    >>> pammi
  4. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Well, after all that, it didn't work, mainly because I
    didn't feel up to searching for hidden files the way my
    graphics were (the search display was very bad indeed)
    and partly because the I then found the driver type and
    attempted a download form driver.com and it kept crashing
    at the same point.
    So basically I gave up and did a full factory reset. I
    needn't have worried need I? I thought a full factory
    reset would be just like the old reformat/reinstall we
    used to do on windows '95 all the time, but it's just
    like a system restore - leaves all your files and email
    intact (though I did back them all up first anyway). So
    that's cool, or I'd be offline for the next couple of
    days reintalling everything.
    Two things I want to know now though, and one I'll post
    seperately about) is how do I changed my display font
    settings (must have chosen the wrong one at startup - the
    default was US everything and I'm in UK England)? And
    also, if factory reset doesn't remove all the old data
    from all the drives, then how on earth do I get rid of a
    virus, supposing one should ever get through my
    NAV/Zonealarm chastity belt?
    pammi
    >Hi Pammi,
    I386 folder on the
    >Best of Luck,
    >> Rick,
    I
    be
    restore,
    have
    installed
    likely
    put
    backing
    have
    >> pammi
    >>>Hi Pammi,
    the
    >> card driver.
    >> is stop it and
    service
    >> and doubleclick
    >> each drive (you may
    >> system folders for
    >> restart it.
    >> System Restore:
    >> to "Show hidden
    >> Also uncheck "Hide
    >> go to the
    >> click it and choose
    >>>install.
    where
    >> your I386 folder
    >> where the
    >> directory).
    >>>Best of Luck,
    >> any
    >> motions
    >> computer
    point",
    >> that
    >> found
    to
    >> be
    >> instead
    it
    >>>> Thanks,
    >>>> pammi
  5. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Hi,
    a) Control Panel/Regional and Language options
    b) Your disk did a reinstall (or parallel install), not a repair. The old
    files are there, but you now have new user accounts. You will likely also
    find that programs need to be reinstalled as well. It basically wiped the
    old system folder (bugs and all) and gave you a new one.
    Best of Luck,
    news:23bb01c4862f$57908350$a301280a@phx.gbl...
    > at the same point.
    > pammi
    >>Hi Pammi,
    > I386 folder on the
    >>Best of Luck,
    >>> Rick,
    > I
    > be
    > restore,
    > have
    > installed
    > likely
    > put
    > backing
    > have
    >>> pammi
    >>>>Hi Pammi,
    > the
    >>> card driver.
    >>> is stop it and
    > service
    >>> and doubleclick
    >>> each drive (you may
    >>> system folders for
    >>> restart it.
    >>> System Restore:
    >>> to "Show hidden
    >>> Also uncheck "Hide
    >>> go to the
    >>> click it and choose
    >>>>install.
    > where
    >>> your I386 folder
    >>> where the
    >>> directory).
    >>>>Best of Luck,
    >>> any
    >>> motions
    >>> computer
    > point",
    >>> that
    >>> found
    > to
    >>> be
    >>> instead
    > it
    >>>>> Thanks,
    >>>>> pammi
  6. Archived from groups: microsoft.public.windowsxp.basics (More info?)
    Heres what worked for me (about an 80% fix). It turns out in my case
    the files in System Volume Information directory were corrupt due to a
    bad problem with Ram.
    I was however able to change the name of c:system volume information
    to system volume information_old. I then created a new c:\system
    volume information directory.
    Then I hit START - accessories - system tools - system restore and on
    the left hand side hit the link to go to settings (NOTE: if you try to
    access by right-clicking on My computer - properties, the tab for
    system restore is GONE!. I TURNED OFF SYSTEM RESTORE and rebooted the
    PC.
    Then turned back on.
    Hit Start - access - ssytem tools - system restore - settings, and
    re-enabled System restore. Then closed.
    Then start - access - system tools -system restorte - and I created my
    first restore point in MONTHS!!!!
    YEah,
    Hope this helps.
    "pammi" <pammi_i@hotmail.com> wrote in message news:<23bb01c4862f$57908350$a301280a@phx.gbl>...
    > at the same point.
    > pammi
    > >Hi Pammi,
    > I386 folder on the
    > >Best of Luck,
    > >> Rick,
    > I
    > be
    > restore,
    > have
    > installed
    > likely
    > put
    > backing
    > have
    > >> pammi
    > >>>Hi Pammi,
    > the
    > card driver.
    > is stop it and
    > service
    > and doubleclick
    > each drive (you may
    > system folders for
    > restart it.
    > System Restore:
    > to "Show hidden
    > Also uncheck "Hide
    > go to the
    > click it and choose
    > >>>install.
    > where
    > your I386 folder
    > where the
    > directory).
    > >>>Best of Luck,
    > any
    > motions
    > computer
    > point",
    > that
    > found
    > to
    > be
    > instead
    > it
    > >>>> Thanks,
    > >>>> pammi
Graphics Cards Microsoft System Restore Windows XP
