Im very interested in getting this Tai-Chi case im not worried about the price or energy costs i just want to know about the performance..
i have never built a water cooled a PC and im a bit lost, so i would like to start with a prebuilt system before i do something wrong and it ends up costing me More.
From what im seeing on this Tai-Chi case compared to other Custom sytems are the diameter of the pipes going to the processor, am i correct in saying that.. the more water the cooler it will run and if so how much cooler?
& something else that im puzzled with is how do you cool the GPU as well
i have seen setups where it is Radiator--->--CPU--->---Gpu--->--Radiator
wouldnt the liquid comming off the Cpu be warm? how optimally would i perform cooling both?
-Thanks
-Water Coolong Newb =/
-Thanks
