Can I keep my FSB @ 200 mhz and run the RAM @ 500mhz? or does it only run @ 400mhz?
Hmm. Not actually sure if modern mobos let you run the RAM at a higher speed than the CPU bus... Don't think there's much advantage to it to be honest. I certainly don't remember seeing a RAM speed option higher than 200Mhz in either my current mobo's BIOS or the previous one (an Epox Nforce 3 mobo). If set to autodetect it might I guess...
Here is another question: While I am at stock speeds, and my FSB is @ 200mhz, my RAM will be at 400mhz right? Can I lower the voltage from 2.8v to 2.6 since it is 100mhz under spec?
The ballistix is rated for 2.8V. at 400 it has tighter timings than at 500, but both are officially 2.8V. You could try it and see, or you may need to relax timings to get 2.6V working. I initially had trouble installing windows because mine had auto-detected 2.6V. You could try it - no one ever killed ram by undervolting/underclocking it! :lol:
I back off my HT a little, set the FSB to 220 mhz and the RAM will run @ 440mhz no prob right? (I mean it is rated t run @ 500!!!)
In theory it should be fine, although you'll probably have to manually set the RAM timings to something a little looser, as it'll probably still try to use the tighter timings from 200Mhz/400DDR. Actually, I forgot to mention HT multiplier earlier! I'll go and amend that little essay in a minute
How hot does your 500mhz RAM run do you think?
Not too sure - I've never touched it and thought it was that hot. My antec case has some built-in temperature probe thingies. I'll stick one on my RAM (other one's on the Gfx card Heatsink). Now I have a board that supports higher VDimm than 2.8V It's probably wise anyway! 8)
Judging from your specs you know all the right stuff to buy.
Been doing this a while, and haven't
always bought the right stuff..... Learning all the time though.
The lesson best remembered is that got through painful experience.
Is the XP-120 worth it? What are your idle and load temps?
Idle in the BIOS was 32C when last I checked. I haven't installed any software for monitoring temps yet, since I've only just reinstalled windows. Plus I really should clean off the HS/CPU and re-apply some thermal paste (I didn't realise I'd lost my tube of arctic silver until I'd already removed the HS and CPU from the old board so I had to re-use what was one there
) at an educated guess, probably mid to low 40s C under load.
The XP-120 is a great cooler, but I believe the XP-90
c (the copper one) gives about the same performance in a smaller package. a pretty worthwhile investment in my book.
Of course these new cores overclock so well that the stock cooler's plenty good enough. I had 2.6Ghz (although not quite 100% stable...) from this chip on the stock cooler when I first got it. It was mostly because of the Noise that I bought the 120. The stock cooler isn't
very loud, but it does make some noise. plus of course load was mid 50s with the stock one (overclocked).
