Tom's Hardware Forums » Overclocking » Cooler and Heatsinks » what's the ultimate watercooling system
Word :   Username :
Bottom
Author
 Thread : what's the ultimate watercooling system
Profile: member
More Information
I want to build a complete watercooled system but my problem is that I am also a complete newbie in this category, also I'm in Sudan in which if you tell anyone about watercooling they will think it is a new kind of an air conditioner.
I saved my money for six months and now I have about 280$ but I don't know what to go for so please Help.I have a cousin in London but he does not know in computers more than my Grandmother (who thinks a computer is some type of insult) but I can send him the money and tell him exactly what I want,but the problem is I don't know what I want so I need help finding the best product for my budget, it doesn't have to be the best but it has to be complete. I mean it has to offer watercooling to every damn thing in my computer (well expect the DVD rom and the Power supply) and here are my specs:
Intel p4 3.07 Ghz (socket 478)
ASRock 845gvi mainboard (supports H/T)
512 mb DDRII ram (PC 2700)
XFX geforce 6200 512mb AGP 8X Graphics Card
Seagate Barrucada 7200.7 80Gb 3.5 inch Harddrive
Touchmate 16X DVD Rom
Hope I get an answer soon.
Related Product
Profile: old hand
More Information
at 280 dollars, it won't get you anywhere close to an "ultimate setup" but more like a mid high end one.
i'm not familiar with UK retailers, but stick wtih something like:
swiftech storm
lain d5
bip3, bix3, or PA 120.3
Profile: member
More Information
Heres a good video from THG that shows you some of the kit you need and how to do it:
http://www.tomshardware.com/howto/20020701/index.html
I found it incredibly informative :D
Profile: member
More Information
I will stick with the Swiftech Storm but i need the rest of the kit because all I know is that swiftech only manufacters CPU coolers. And I also need a reservoir, pump and some tubing, could you help please.
also I didn't understand what lain d5 or the other words meant
Thanks for your response
Profile: member
More Information
tried and tested.(most importantly, within your budjet :wink: )
http://www.cluboverclocker.com/rev [...] te/galaxy/
Profile: old hand
More Information
omfg no, thats a disgrace to watercooling
Profile: Honorary Master of THGC
More Information
I preferred TT BigWaterSE
Profile: old hand
More Information
lol semi-disgrace to watercooling
Profile: member
More Information
Quote :
"]omfg no, thats a disgrace to watercooling
Again dont make blanket blind statements!! quote your sources by pasting links otherwise best remain quiet. :!:
jumping in to a dialogue without basis doesnt tell well your on intuity.
Every water cooling system has its pros and cons. this one has cons too but has very good reviews and proven effective cooling.
(the only con was the first few batches came with smaller heatsinks but now i saw the newer ones dont have that problem)
:arrow: he wants something within his price range with good performance and it fits well into that description. You yourself already posted to him that he cant get the "ultimate setup" with that amount so we are working with the phrase cheap but good
The only side effect it has is that he cannot brag about building it himself, which i guess he doesnt mind. Note that the OP lives in Sudan, i too have lived in Africa for some years and i am aware that due the relative absence of computer hardware shops(not like europe or US) , it will be to his advantage to just buy a kit (which parts already fit together)and just set it up, instead of differernt parts seperately while risking the fact that he cant easily send then back if they dont fit or are not fully compatible with each other. In Europe & Us however it is easier to just send an unfitting part back and get the right size.
:idea: Reading this you will note that i have thought this through before i posted, i advise you do the same next time before posting
@ RichPLS
true that the TTbigwater also has good reviews, but as regards the Gigabyte 3D i will give you more links showing its performance(it even beats TT bigwater)
Therfore being reasonable,you must confess that it is good value for the low price.
http://www.xbitlabs.com/articles/c [...] rs_27.html
http://www.xbitlabs.com/articles/c [...] alaxy.html
Profile: old hand
More Information
you are basically compairing poo to pee, they both stink -_-
for the price given, a much better KIT would be those swiftech apex "heavy duty" ones with the storm in them.
okay, you want to know why the gigabye watercooling sucks?
realize in your links, the testbed is
1)inconsistent due to the fact that its an CPU instead of a controlled heat source
2)a 2.8 smithfield... and the idles are 58+ fyi... those temps are crap
so again, put a good watercooling loop in there and you'll definitly see the difference. so in the end in terms of price vs. performance ratio, the galaxy is really not worth it
Profile: member
More Information
Quote :
For an MSRP of $120 then weighing against its performance it's damn not worth it.
Again i am disapointed that you cant see that price was before it was even released, it costs less than that now and mind you even at $120, for a water cooling system thats cheap!!
Quote :
Again you talk blindly, i guess what you are trying to say is that all cooling experiments (including air cooling reviews)done with CPUs and not controled heat sources should be debunked?? 8O 8O
What is a review? placing a product in real life situations and charting its performance PERIOD. ofcouse like any experimant there is a margin of error but this can hardly be reponsible for that much a differnce in performance.
secondly, look at the other reviews (i gave more than one due to" doubting thomases" like you). if you dont like the smithfied(i cant see why) the second experimant was done with Prescott overclocked to 4.1 Ghz....smooth heat i would say!
If you dont have resonabe points then stop manufacturing funny objections.
Profile: old hand
More Information
UMM... i'm not saying all tests done w/ cpus should be disregarded, but only the fact that you should take them with a grain of salt, especially with a burn program. procooling (probably most legit watercooling review site) does all of their tests on a stable heat source.
the simple fact at the end of the day is, the galaxy doesn't perform well, no matter how much you rave about it. it can't add a gpu block as it can't take the heatload.
at best, the performance will be slightly better than an aircooler costing half the price and much easier to install.
and btw... am i crazy or is that 4.1 preshott idleing at 35! O.O
one last thing, realize these "kits" built by gigabyte where never meant to compete with real watercooling
Profile: member
More Information
Quote :
"]UMM... i'm not saying all tests done w/ cpus should be disregarded,
At least you admit that.
Quote :
i have poteded links to support my school of thought you have brought forward nothing.
I rest my case.
Profile: old hand
More Information
alright, its not like any testing has been done with the delta of inlet and outlet temps of the waterblock, so i can't really give you a link showing how poor this thing performs, just to give you an idea, to go procooling and check some of its waterblock testing. you'll find theirs to be very scientific and consistent.
Profile: member
More Information
Quote :
"]alright, its not like any testing has been done with the delta of inlet and outlet temps of the waterblock, so i can't really give you a link showing how poor this thing performs, .
Profile: old hand
More Information
uhh.. yay?
More Information
