Com port redirection problem
G
Guest
Guest
Archived from groups: microsoft.public.windowsnt.terminalserver.client (More info?)
Hello!
I am testing com port redirection. When I use the command:
net use com3: \\tsclient\com2
and checked it with net use it displays the following:
Status Local Remote Network
C: \\TSCLIENT\com2 Microsoft Terminal Services
OK L: \\dco1\felles Microsoft Windows Network
OK P: \\dco1\program Microsoft Windows Network
OK R: \\officedc01\rubicon Microsoft Windows Network
OK T: \\officedc01\rubdata Microsoft Windows Network
OK W: \\dco1\rsodok Microsoft Windows Network
Unavailable Z: \\officedc01\d$ Microsoft Windows Network
The command completed successfully.
It is correct that it says that "Local" is C: I tried to communicate with the modem on my tsclient, with no response. The modem is connected to com2 local port. Is it more I have to configure? I have also tried to disabled the local port.
Thanks for the help!
G
Guest
Guest
You should enabled Com port redirection on the client UI and make sure on
the server com port redirection is not disabled.
Any direct reference to the com port on the session should redirect to the
local port without mapping.
Zenon Pilat (MS)
This posting is provided "AS IS" with no warranties, and confers no rights
"LaWo" <LaWo@discussions.microsoft.com> wrote in message
news:4354F286-BBE6-4866-ABE6-0315665508B3@microsoft.com...
> Hello!
Services
Services
the local port.
