Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Looks like if I want to roam from room to room with my laptop I want
wireless.
"Michael T" <anonymous@sbcglobal.net> wrote in message
news:u4RUfiLxFHA.3112@TK2MSFTNGP10.phx.gbl...
>I want to access my desktop (with a router) using my notebook (laptop) in
>another room.
> Putting firewall/security considerations aside, do you recommend a
> wireless router or a hard wired router.
> Please advise. If you could explain why you recommend one over the other
> that would be great.
> Thank you.
> Michael
One downside of wireless is file transfer speed, its nearly always better
using wired, especially for large files.
philip ashley
news:eUvahaMxFHA.3740@tk2msftngp13.phx.gbl...
> wireless.
>>another room.
>> Thank you.
>> Michael
All common wireless routers allow both type of connections. You should always
have the capability to connect via wire for certain setup functions and bios
upgrades.
> another room.
> Putting firewall/security considerations aside, do you recommend a wireless
> Thank you.
> Michael
"Philip Ashley" <philip.ashleyRE@MOVEntlworld.com> wrote in message
news:JZM_e.2795$0w.356@newsfe5-gui.ntli.net...
> philip ashley
Kudos Philip as this is just the kind of information I was hoping my post
would produce. Also thanks to DanR for his feedback as well.
But I am a bit overwhelmed with all the different routers available.
I plan to use this notebook (roaming from room-to-room) on a WinXP Home
Network with a desktop (the ICS host) in my bedroom.. I also will be using
it with public hot spots when I travel.
So I have would I hope are some simple questions about wireless routers for
you gurus.
Given my planned usage do you recommend a Wi-Fi router (e.g. the Orinoco
BG-2000)? Or will a NON-Wi-Fi router like a Linksysy WRT54gs suffice?
Also, if I use the Windows XP ICS software on my ICS host (a desktop in my
bedroom) to share its DSL connection with my notebook, do I need the DSL
software (from my ISP) installed on my notebook as well?
news:e9d84bSxFHA.3152@TK2MSFTNGP10.phx.gbl...
>> better using wired, especially for large files.
>> philip ashley
> post would produce. Also thanks to DanR for his feedback as well.
> Home Network with a desktop (the ICS host) in my bedroom.. I also will
> be using it with public hot spots when I travel.
> routers for you gurus.
> Orinoco BG-2000)? Or will a NON-Wi-Fi router like a Linksysy WRT54gs
> suffice?
> in my bedroom) to share its DSL connection with my notebook, do I need
> the DSL software (from my ISP) installed on my notebook as well?
> Michael
No ICS! A router manages your network. Each computer is connected to
the router, wireless or wired. The modem is connected to the router.
Depending on your ISP you *might* have to clone the MAC address of the
wired computer to the router, but most of the time a simple power cycle
of the modem will let the router become the connected computer with the
single IP address assigned to your account. You should check with your
ISP for any guidelines for using a router, or check www.dslreports.com in the forum for your ISP on how to set it up.
> > philip ashley
> you gurus.
> Michael
You're a little confused in your terminology. "wi-fi" generally is used to
refer to any wireless networks in general
(http://en.wikipedia.org/wiki/Wi-fi). Thus, the Orinoco BG 2000 and the
Linksys WRT54gs are both "wi-fi" devices. The BG-2000 came at in 2002. I
don't think you can buy one anymore, and Proxim calls it an "end-of-life"
product (meaning, I think, that they know that it's out in the filed, but they
don't intend to support it very much longer).
Although the Orinoco unit was called a "gateway," these days, that term is
often used to mean a device that combines a router, perhaps a wireless access
point, and a cable or DSL modem. I don't think that the BG 2000 had the modem.
The Linksys WRT54GS definitely does not have a modem. It is, however, a
combination of a 4-port router (i.e., you can connect up to 4 ethernet cables
to connect to PCs and/or other network devices) and a wireless access point.
Like most other home routers these days, it has NAT capability and a firewall,
and has a built-in PPPoE client. Although there are those who post to this ng
who have little good to say about Linksys products, I had a WRT54g version 1.0
and was perfectly happy with it until it got partially fried by a nearby
lightning strike. I replaced it with a WRT54g version 4.0 (Linksys seems to
have just come out with a 5.0).
The "s" on the end of the WRT54gs indicates that it has Linksys' proprietary
"speedbooster" technology, which Linksys claims will give you "up to 35%
increase in speed over standard Wireless-G when used with other SpeedBooster
products." The key here is that you MUST use other Linksys "SpeedBooster"
products to even have a hope of getting this increase. If you have a new
notebook with a built-in wireless access device, it almost certainly is NOT a
Linksys "SpeedBooster" device, and you therefore ought not to spend the extra
money for the "GS." Linksys also has an even (allegedly) faster version, the
WRT54SRX. Here's the Linksy page comparing their 3 varieties
http://tinyurl.com/9xqqh. If I were you, I would just get the basic WRT54G.
Check out http://www.ezlan.net/ for further info. Don't just look at the
"wireless" sections. There's a lot of other information there.
"Quaoar" <quaoar@tenthplanet.net> wrote in message
news:uentz2SxFHA.900@TK2MSFTNGP11.phx.gbl...
> No ICS! A router manages your network. Each computer is connected to the
<snip>
> Q
Thanks Q.
Although I have tons of experience as a software engineer I am a total
newbie when it comes to configuring a home network using Windows XP.
I will defer to your judgement as I have only been researching two days. But
I do find it interesting that the WinXP Help file recommends that the first
step is:
"Run the Network Setup Wizard to setup your ICS host computer."
So you can understand why I might be a bit puzzled when you stated "No
ICS!".
Yeah, if you want to use XP to distribute the internet connection, which from the sounds of it you don't. You could use ICS or other NAT/Proxy software solution on a XP host machine but it's not the preferred method. A router, and for you a wireless router, would handle that role.
Wi-Fi is a certification by WECA. Basically it means the device has been tested to interoperate with other Wi-Fi compliant devices. Doesn't mean non Wi-Fi certified wireless gear won't work but they would be untested by WECA. Pretty much anything you see will be Wi-Fi but if you want the golden stamp of approval look for the red Wi-Fi lable on the box. The WRT54G series, including the GS are definitely Wi-Fi compiant.
