Tom's Hardware > Forum > CPU & Components > CPUs > Overheating problems
I've read a lot of posts about Intel CPU's overheating with stock heatsink and fans... Is this while idle, or during long hours of gaming?
I just got a 3.4 Ghz Pentium 4 HT 650, on an ASUS P5P800 motherboard with just stock heatsink and fan... should I be worried? Or would getting something like a Thermaltake 775 do the trick?
Not using it for gaming, just video encoding and day-to-day use...
Thanks,
Sponsored Links
Don't worry about it. I had a stock fan/heatsink on my P4 3.4Ghz for 1.5 years and never had an issue. Do you really think Intel would sell/design a heatsink that doesn't work?
All you need to do is clean it occassionally. This is true of any heatsink/fan.
-mpjesse
Reply to mpjesse
Good to hear, thanks for the reassurance!
Reply to Momo3
The stock heatsink is generally fine ... so long as the case has good airflow. What kind of case and case fans are involved?
Reply to slvr_phoenix
It's in a Raidmax xA568 mid tower...
Reply to Momo3
Quote :
Not stunning, but not bad. So that's an intake 80mm fan and the PSU for exhaust. Do you have one or two of the optional 80mm exhaust fans installed? If not, I'd suggest that you look into adding them.
I was looking at ecollegepc.com to order it, those were all the specifics that i was going to order... it looks like it has 2 fans, but i e-mailed customer support to check.
Reply to Momo3
There are 1217 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
