ok im not quite sure of the cause of this problem so im going to post it in this forum.
From the beginning.. 2 days ago i bought a new cpu motherboard graphics card and 2 HDDs.
So as it stands my pc is athlon 64 3700+, Asus A8N5X pci-e mobo, 2x512 corsair value select RAM, ATI radeon x800 GTO 256mb pci-e, 2x SATA maxtor 160gig HDD. My PSU is a tagan 420w ATX2.0 so its fully compatible with my board and PCI-e card.
I proceeded to upgrade my old PC with the new cpu mobo gfx and hdds. when it was finished and id made sure there were no jumpers that needed setting i switched it on. Now the power seemed to be running through the computer, all the fans were working including on the gfx card but the monitor didnt come on. the monitor was working last nite on my old PC so i know its not that. The computer hasnt made any obvious beeps, just a really half hearted crunchy beep when i first press the power button in. Ive had problems like this before but after a few trys with a new pc it will work. this time it isnt. so far i have taken everythin out and stripped it down to the basics. Just the mobo, cpu, gfx card, 1 512 stick of ram, 1 new clean HDD and 1 CD drive and of course psu. it still is not getting anythin on the monitor. Ive tried resetting the cmos as well. i have the gfx power plugged in correctly. another thing, when the computer is on, i cant switch it off by the power switch and the reset switch wont work although these are connected correctly.i have to switch it off by the psu switch on the back.
Anyone have any ideas? any help would be brilliant, Thanks for reading and thanks in advance.
