hi
i got a new graphcis card, the geforce 6600GT
i can't get it to work
i've posted other placed on these forums about it, but now i have a different piece of the puzzle
i'm almost 100 percent sure it's the motherboard now, but i don't know why
When i put in my new geforce 6600GT card, and i go to hardware monitoring, it says that the 12V rail is .12V, the 5V rail is .05V, the 3.3V rail is .03V and the VCORE voltage is .03V. These values never flicker, never waver, and are in red.
When I put back in my old geforce III card, and i go to hardware monitoring, it says that that all the rails (which are now in blue) are close to what they are suppose to be. This means that the 12V rail is 11.9V, the 5V rail is 5.05V, the 3.3 rail is 3.1V and the VCORE voltage is around 3.1V. Also, these values flicker back and forth just a little bit, the way they would when measuring the voltage using a multimeter.
I think fundamentally this is a power problem. However, the thing maybe that the motherboard won't regulate so much of a power drain. This is all guessing and I'd really like it if someone from ASUS could help me out.
However THIS is what is causing the problem. How to fix it though... *shrug*
i've made sure my power supply is big enough, i've done the driver thing, i've done the bios thing, i've done everything that I can think of
in light of this new information, what do you suggest?
