Tom's Hardware > Forum > CPU & Components > CPUs > best system possible
Forum CPU & Components : CPUs - best system possible
what is the best system that can be made including monitor, mouse ,keyboard etc, for under $10 000 canadian and then under $5 000 canadian
also what are the parts of a system to compromise on with buget problems example: get fx-55 instead 0f fx-57 to get better video card etc
Sponsored Links
This depends on what the system will be used for
DIY systems
GAMEING:
opteron 148 (939) good OC proc (single core)
asus sli or dfi ( dfi sli-dr expert: for optimal system tweakabilty note not a noob mobo)
2gig ddr 500 or 550 for OC'in ( corsair, OCZ, mushkin, G-skill )
7800 gt in sli will play anything nearly if not at max res ( eye candy )
2x 74 gb wd raptors
X-fi sound card
Nec lcd 8ms monitor
( if you go with a xtreme Oc able mobo consider going with a liquid cooling sys. make damn sure you have a big enough case for it)
muti-media:
opteron 165/170/175/180 Dual core proc
2gig ddr 400 corsair
asus a8n-e or Msi k8 neo4 platium
4x 250GB sata II HDD ( seagate, WD, Hititchi )
6800 gs pcie card
x-fi sound card
NEC lcd 8ms monitor
Manufacture built system
Falcon northwest ( the best to buy a built sys from, and very good support)
Alienware ( rock solid systems)
For what you could pay a company to make for you, you could do yourself much better with a DIY sys, only difference is the support of the company with the product you have bought from them
other good mobo's are eprox, gigabyte and abit. All prices will very
just to note the listed above are all good products, doesn't mean you won't get a dud part some where in a DIY sys and really based on my opinion..do the research bro ask the question here. alot of good knownable people here mostly to include the (long time posters that have been playin with PC's since the 8088 proc was out and DOS was loaded with a 5.25 floppy drive :lol: not to mention bill gates was still a college nerd just not rich yet!!!)
They mite sound like grumpy old men it just means that the hemroids are flareing up on them :mrgreen: ( some are ladies :tongue: )! either way they will help lead you to a good choice for you dwell on!
good luck
Reply to jokersgrin
Make sure u get @ least 2 150gig Raptors for a RAID 0.
Reply to K8MAN
Addressing just the monitor portion...
Dell has a new 30" computer LCD monitor out, capable of 2560x1600 resolution, for about $2200 USD..
I imagine it will be the Alpha monitor for quite a while!
(Although for $501 on sale, the Dell 2001FP is quite excellent, and if you prefer a widescreen, the 2405FP at 24" and about $900 on sale is also nice)
Reply to mdd1963
my bag wusy... fat fingered it :tongue:
Reply to jokersgrin
If you're spending that much money, RAID 5 would be a much better option than RAID 0. RAID 5 gives you speed and redundancy... but if one of the drives fails in a RAID 0, your data is toast.
Reply to Zoron
RAID5? Why not RAID50?
Reply to Crashman
Quote :
Consider checking out this as a base spec.
http://users.on.net/~darkpeace/har [...] on270.html
For best stability feature set get Single Rank* x4 DIMMs
* Not to be confused with bank, or sides of a DIMM. Thus can attempt use of 1T CMD rate, as each Opteron supports up to 4 ranks of memory at 1T.
* x4 (vs x8) and populate "all DIMM slots" for correct ChipKill (tm) operation. You'll still get stock Registered / ECC operation if you don't, but you can get a 'enhanced ECC' by using x4 ECC Reg DIMMs and populating every slot on the board from the word go. x4 means each chip on the module is only 4 bits wide, instead of 8 bits wide externally, but their are more chips on the module. This is a documented requirement for ChipKill (tm) functionality and often not included in 'off the shelf' Opteron systems sadly.... The Kingston KVR400S4R3A/1G meets this requirement, not much else on the marketplace does.
PDF: http://www.valueram.com/datasheets/KVR400S4R3A_1G.pdf
Seriosuly worth getting familar with the above ^ if spending $4,000 or more on a PC (be it workstation, server, or somewhere in between). Nothing comes close for Autodesk 3D Max, etc to the above system in the same price range. (as of the date I built it anyway, but don't get a Radeon X800XL if you're expecting to do heavy 3D work on it. Get a ATI FireGL or Quadro video card instead, or use the SLI feature).
The Tyan K8WE is a good Opteron workstation / server hybrid board in the AU$5,000 price range. (AU and Can dollars are roughly equal). The SCSI is optional but SATA is fine these days. Tyan Thunder K8WE supports RAID-5 on SATA after BIOS update 1.02.
Windows XP and XP x64 Edition both support two CPU SOCKETS (with no limit on cores per socket, 'legally' anyway). Although in reality a MS patch would likely be required to enable 'above 4 core' support in XP/XP x64.
I have been lazy and not updated the website ( http://users.on.net/~darkpeace ) for awhile, the link to the above is currently broken from the site.... fix this weekend maybe :P ...
Just get the fastest Dual-Core Opterons you can, 2.4 GHz, so Opteron 280 is currently the highest there (Run 2 x Dual Cores, for 4 x 2.4 GHz cores), and if Media Encoding get the WME9 x64 update from: http://www.microsoft.com/windows/w [...] fault.aspx
Unless you only want 2 cores / 1 socket at 2.6 or 2.8 GHz, but then you might be looking more at Intel Pentium D EE (2 cores, each HyperThreaded, excellent for Video) in addition to the AMD Athlon 64 X2 and AMD Athlon 64 FX-60.
Really depends what you are after, fast 'core isolated' thread performance, or 'powerful' dual core, or quad core.... You could afford an Opteron 800 series (running 4 x dual core CPUs, for 8 cores... or 16 cores over 2+ boards). in the $10k price range surely.
OR....
Are you just trying to build (yet another) gaming PC ?, if so you'll get massively diminishing returns past about $3,000.... as very few (if any at all ?) games are designed for 4+ core systems.
Otherwise, if you are truthfully in need of a Quad-core AMD Opteron / Intel Xeon for whatever reason, feel free to MSN or é-mail me (see: http://users.on.net/~darkpeace ; for my contact details); I can share benchmarks, NUMA config tips, etc with you.
Reply to TabrisDarkPeace
Athlon64 FX57 S939 Athlon64 FX57 2.8GHz 1000FSB 1MB L2 Cache Socket 939 (AMD64) (Retail) $1250.00
Kingston 1024MB PC3200 Kingston 1G PC3200 DDR400 KVR Non-ECC CL3 $108.00
A8N-SLI Premium Asus A8N-SLI-Pre NF4 S939 1066FSB DDR400 PCIE16 PCIE8 2SLI 2PCIEx1 3PCI SATA300-R SATA-R5 i1394 USB2.0 7.1Audio 2x G-LAN ATX AI-Selector Cool-Pipe $215.0
Barracuda 500GB SATA-II Seagate 500GB 7200RPM SATA-II 300bit/s 3.5" 16MB Cache $405.00
3550A-BK DVD-/+RW 16x DL 8x NEC 3550A DVD+-RW 16x Dual-layer 8x DVD+R, Dual-Layer 6x DVD-R Black $50.00
7800GTX 512M PCI-Ex16 eVGA nVidia GeForce 7800GTX 512M 1700mhz-DDR3 SLi HDTV-o Dual-DVi PCI-Express x16 (full ver) $980.0
VA2012WB 20" Wide-LCD DVI BK Viewsonic VA2012WB 20" 16:10 Wide-LCD 1680x1050 600:1 8ms 300cd/m2 Speaker VGA DVI Black wall-mountable $990.00
Sound Blaster X-Fi Elite Pro Creative Sound Blaster X-Fi Elite Pro Sound card 24bit 192kHz 116dB SNR 7.1 PCI $430.00
Gigaworks S750 THX Certified 7.1 Speaker System 7x70W Satellites 1x210W Subwoofer w/ Wireless Remote $481.00
Antec SONATA II 450W ANTEC SONATA-II TAC Middle-Tower Black SMARTPOWER 2.01 450W 3x5.25" 2x3.5" 4x3.5" $122.00
Truepower II 550W ATX12V 2.01 Antec TPII-550 TRUEPOWER 2.01 550W POWER ATX12V 20Pin+4pin Quiet / Silent $104.00 (if Needed)
diNovo Bluetooth Media KB & MX900 Mouse Logitech Bluetooth Keyboard + MediaPad + MX900 Bluetooth Optical Mouse + Bluetooth Wireless Hub $240.00
Prices are in Canadian dollars. Any duplicates are meant to be there. ie. 4 gigs of ram, 2 19" lcds, 3 hard drives.
Total Cost in CDN$ before tax: $7167.00
Total cost in CDN$ with taxes (cdn 14.5%): $8206.22
Total cost in USD with CDN taxes: $7071.28
This may not be the fastest, or the best. I made this up in like 2 minutes. But anyways, i dont think anyone can argue it would rock.
Reply to Ian
Quote :
1G DDR533 180pin Kingston 1024mb DDR533 180pin PC2700 CL2.5 non-Ecc $110.00
A8N-SLI Premium Asus A8N-SLI-Pre NF4 S939 1066FSB DDR400 PCIE16 PCIE8 2SLI 2PCIEx1 3PCI SATA300-R SATA-R5 i1394 USB2.0 7.1Audio 2x ....
meh, looks like Ian just fixed it ;)
Yeah my bad, just got a little hasty with the ctrl-v :)
Should work now, 4 gigs of DDR 400
Reply to Ian
Still say, get a real mainboard:
Thunder K8QW (S4881) (4/8-way / Opteron 800 series)
http://www.tyan.com/products/html/thunderk8qw.html
or
Thunder K8WE (S2895) (2/4-way / Opteron 200 series)
http://www.tyan.com/products/html/thunderk8we.html
(and ECC Registered memory for them).... you'll still get over 8,000 MB/sec in the SANDRA memory benchmarks because of ccNUMA.... likely over 16,000 MB/sec on the K8QW but it prob can't do SLI 7800's because it would be too tight a fit.
Why do I feel like this is just another 'gaming rig' thread ? :P
The K8WE is supposed to be a good board :-) I've only used the Tyan S2882 so far which is a true server board unlike the K8WE which is a workstation board and has an x16 PCI-Express slot and an x4 PCI-Express slot.
[code:1:49443a9593]
EDIT:
I was referring to the OLDER K8WE S2877G2NR and S2877ANRF which only has 1 usable x16 slot.
The wise poster above is referring the new version S2895 which has 2 x16 slots :-)
[/code:1:49443a9593]
A Dual Opteron (model 2xx socket 940) or 2x Dual Core Opterons (model 2xx socket 940) or Quad or 8way board with model 8xx socket 940 Opterons would run a lot faster.
The Quad board sells for about $1000 USD and the 8xx Opterons go for about $1200 each [852 @2.6GHz].
64bit Linux would run best on a 2 way 4 way or 8way Opteron btw :D
Reply to linux_0
Yep, Also the older Tyan K8WE required a 6-pin connector for additional power, the newer one uses the more standard 8-pin EPS12V connector.
Tip: If you do find yourself with the older one (rare these days), then you'll need a 'more funky' PSU. Do not try to plug a 6-pin PCIe power connector into the older revisions CPU power. It would most likely fry the mainboard very quickly. From memory the PSU was an early AMD design and had a "G" in the name of spec.... Like GTX or something (can't recall as I have the 8-pin EPS12V rev).... but it would be documented at: http://www.amd.com/us-en/Processor [...] 23,00.html ; just in case you need it. ;)
There are 451 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
