PSU power question
de
4
Im planning on building a computer with the Arctic Cooling Silentium T3 case (http://www.arctic-cooling.com/pc_ca...ata=1&disc=).
Hardware:
XFX GeForce 7800GT 256MB GDDR3 eXtreme
AMD Athlon 64 X2 3800+
MSI K8N SLI-FI, nForce4 SLI, Socket-939
Can the 350 PSU that comes with the case handle this system?
You're link doesn't work. What other components? The number of HDD and cd/dvd drives makes a difference. Are you planning on SLI?
If it is a Seasonic, then it might work if you are just running a 2-3 drives (HDD, DVDRW and DVD/CD) and not in SLI. If you're SLI, then I would say no.
