Tom's Hardware > Forum > Smartphones & PDAs > Windows Mobile > HELP -Bluetooth Not Working
Forum Smartphones & PDAs : Windows Mobile - HELP -Bluetooth Not Working
Archived from groups: microsoft.public.pocketpc (More info?)
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
I use a IPAQ 1940. Suddenly when I start up my Pocket PC I get a
message that says "BTTrayCE' is not a Vaild Pocket PC Application".
Then when I go to Setting ...Bluetooth: Its says Bluetooth is OFF,
insert a Bluetooth card to turn it on."
Any idea what caused this and how I can fix it? I am worried it is
something in the registry that I may have screwed up.
Thanks a million
Due to large amount of spam mail as well as personal security, please
respond directly to this newsgroup. Encrypted Messages, using PGP can
be posted in alt.anonymous.messages, please place
"D43E68CD14F2AD50465A4CF3D8C4DC1C99C221A5" in the subject of the
message.
PGP Security Key: 0xB093E95A (I no longer use the key - 0xE0685B4D)
-----BEGIN PGP SIGNATURE-----
Version: PGP Personal Security 7.0.3
iQA/AwUBQT9fcdjE3ByZwiGlEQJrFgCfdVMITttqYT7mWxbWDJPuJmvPYKcAn17O
ecfYZ/MiwwG4yPMxnTvUCP1i
=mASP
-----END PGP SIGNATURE-----
Sponsored Links
Might be something you have installed, but it could be a hardware problem.
First thing I would try would be to backup my device to an SD card,
hard-reset it, try Bluetooth to see if it works and then, if it does,
restore the backup and check again. The three possibilities in this case:
1. It doesn't work immed. after Hard Reset: you have some hardware problem.
2. It works after HR and continues working after restore: problem solved
3. It works after HR and stops working after restore: something in the
device is bothering. You should try uninstalled the applications installed
lately until it begins to work again.
Helio Diamant - MS/MVP Mobile Devices
http://www.pocketpcfreak.com
"The Subject ®" <The_Subject@underground.com> wrote in message
news:2q95d1Ftl05aU1@uni-berlin.de...
> Hash: SHA1
> Thanks a million
> message.
> =mASP
Reply to Anonymous
Is there any chance it could be a screw up in the registry? I found out my
kid was playing with it and was in the registry.
Thanks
respond directly to this newsgroup. Encrypted Messages, using PGP can be
"D43E68CD14F2AD50465A4CF3D8C4DC1C99C221A5" in the subject of the message.
"Helio Diamant - MS/MVP, Mobile Devices" <helio@nospam.pocketpcfreak.com>
wrote in message news:OUhhSsklEHA.2612@TK2MSFTNGP15.phx.gbl...
problem.
> > Hash: SHA1
> > Thanks a million
> > message.
> > =mASP
Reply to Anonymous
It could be. But then, it would be almost impossible to see what he has
messed up with. Again, the HR would restore it to the original, and if this
is the problem the restore of the backup would mess it up again. So you
would know, and another HR, with further installation of your software from
scratch, would solve the issue.
Helio Diamant - MS-MVP/Mobile Devices
Editor-in-Chief
Pocket PC Freak - The Hebrew Pocket PC site
news:2qbeklFtmuliU1@uni-berlin.de...
> Thanks
problem.
case:
> problem.
installed
> > > Hash: SHA1
> > > Thanks a million
> > > message.
> > > =mASP
Reply to Anonymous
Just a quick note. Turned out the Bios I upgraded to fryed my entire system.
I sent it back to HP who returned it fixed, and replaced a cracked cover for
no charge at all. Additionally the entire time out of my hands was about 72
hours. I am very very impresssed with HP's support in this.
And yes my Bluetooth is now working.
"Helio Diamant - MS-MVP/Mobile Devices" <helio@nospam.pocketpcfreak.com>
wrote in message news:OMHW%23bvlEHA.2968@TK2MSFTNGP14.phx.gbl...
this
from
> Editor-in-Chief
my
> > Thanks
message.
> problem.
> case:
> > problem.
solved
> installed
> > > > Hash: SHA1
> > > > Thanks a million
please
can
> > > > message.
> > > > =mASP
Reply to Anonymous
There are 1058 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
