Archived from groups: comp.periphs.printers (More info?)
Black head virtually no output.
Have removed cartridge and dribbled alcohol onto the little spike and
wiped it with a cotton wool bud.
Can I disembowel it and have a go at cleaning the 'paper' side
nozzles?
>nozzles?
>TIA
>Bill
"Bill" <bill@howcroft.me.uk> wrote in message
news:k4h2p0lajnjcm05b5hctjhd7ur49gd42bh@4ax.com...
>>nozzles?
>>TIA
>>Bill
> Have been trying this:
> http://www.inkjetart.com/tips/cleaning/inserted.html
how printers do you have bill? or are you a different bill?
and
> nozzles?
> TIA
> Bill
Bill:
Use the find function in your newsreader to search for the name
"Arthur Entlich" on this group
or do the same with a search engine. If you write Mr. Entlich and
request that he send you a
free copy of his excellent cleaning procedure manual for Epson
printheads, you won't be disappointed.
news:j5e2p0pfag25cnmqsc5dlk8prvke0etgpv@4ax.com...
> nozzles?
> TIA
> Bill
Basically don't attempt the disassembly of Epson printheads. All effective
cleaning can be done without that.
If you have a spare cartridge the best way is to fill it with Windex
(Windolene UK) and print a few pages with that as and when the black fades.
Mr Muscle a shower degeaser works fine as well. The ammonia content in these
cleaners acts as solvent for dye and usually pigmented inks. Household
ammonia diluted 10:1 also does the trick. And if possible ignore all the
parrot pratts who occasionally visit these groups with their prophecies of
doom. The solvent only stays in their for a few minutes and is flushed
through by the next load of ink.Some vendors also provide a solution which
is basically the same mix.
Tony
Spit less spotlets - spotless inkjet prints...
http://www.inkylinkusa.com 30% more ink
http://www.aah-haa.com/affiliates.htm And a nice little earner...
If you haven't already done so, send me a private email referencing your
printer in the body of the message and I will send you instructions for
cleaning your Epson printer without disemboweling anything.
No cost for the manual which is sent by email.
Art
> nozzles?
> TIA
> Bill
