Sorry if this is the wrong area for this question, but..
is there a solution out there for cleaning components, INCLUDING system fans? That will not destroy the plastic fans? I used some cleaner that was supposedly "safe for most plastics", but soon as it hit my cpu fan the fan ( plastic ) just popped right off and broke. I since tested it on an old 120mm case fan, same thing. So, I was wondering if there was any so called " computer bath" type stuff out there? Just a spray and go type stuff.
Thanks..!
Thanks..!
