I was just wondering if anyone knew any tricks to get the VPN Client
working on an XP machine.
I installed everything properly, set up the tunnel and when I try to
connect, it actually says that the tunnel is connected and the
security gateway is connected. However, I can't ping any of my servers
and I can't get to my mail server.
I turned off ICF/ICS so I know that isn't the problem. Unfortunately,
I can't figure out anything else to look into. Any ideas would be
great.
