G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Friday,
08.20.'04
"I can't get no power Captain!" Traditional response of
Scotty to Kirk, Starship Enterprise.
Among other essentials, I have two H.P. laptops- the
first, the older model, an H.P. Pavilion ze4125, the
second, an H.P. Pavilion ze5600.
Some time ago, the ze4125 flashed a notice that the
battery power was getting low and that I should recharge
the battery. I meant to do so just as I have in the past
when necessary, but this time I delayed and delayed and
delayed the maintenance duty.
Although I run the unit on electricity with the battery
plugged in, within the last week or so, when the unit is
about to shutdown, it seemed to turn off with an
exceedingly weak little "ting" as the screen went black
not the usual, robust "TING!" of times before. It seems
as if the unit is taking longer and longer to power up as
well. I thought, OK, no doubt about it- time to recharge
the battery. I went to, "Control Panel", "Performance
and Maintenance", "Power Options", "HP Battery
Optimizer", "Start" "Test Battery". On, "Test Battery",
on prior occasions, I could not get the "Next" command to
engage, it remained dimmed and inaccessible. As of
today, I can access the "Next" command but the unit
says "Error: Battery Communication. Process Terminated."
My question is, is there some keyboard command, something
akin to "ALT +5" or "Control Key + F10" which can
override routine established protocols and force the unit
to recharge the battery. At this point, the unit states
I have "0" battery power.
The unit still functions. Also, what would happen if I
took the battery out of the ze4125 and tried to recahrge
it in the ze5600? Would such action destroy both units,
switching batteries like that?
Hope you can help. Thanks for listening.
De Dean
Friday,
08.20.'04
De Dean
