Questions about Hauppauge WINTV-PVR 500 Dual tuner card.HELP
Ok i own a media center edition computer with no tv tuner. I am looking into buyign a tv tuner. Preferrably one that can tune in 2 channels. Thats when i came across this one. So here are my questions. Please help me on these.
And to let you know incase these play a role into any of the answers i have:
Dual PCIe 16x Geforce 7800 GTX 256mb
Pentium D 3.2 gHz
2gb DDR2 ram
and only 1 PCI slot available.
Questions:
1. Do i need only PCI slot to take full advantage of all the features on this card?
2. I have cable television. Will this card allow me to plug 2 cables into it to watch 2 channels? (basic stupid questions but just to make sure.)
3. I see this card has one RCA (red white and yellow plugs) That allows input from DVDs and such input correct?
4. Can i buy a separate remote for MCE to work with this tuner?
5. And i have come across one bad review of this item in conjunction with a Dual core computer (which i have) is this true?
thanks in advance
3 answers Last reply
More about questions hauppauge wintv dual tuner card help
  1. I don't have one of these boards but I have had several AIW boards so I kinda know what is going on with the Hauppauge.
    1) Yes you only need one regular PCI slot for the board.
    2) From Hauppauge's web site: "Includes a built-in TV splitter, so you only need to make one connection to your television cable."
    3) Yes, you can hook up an external video source using S-video or composite (yellow).
    4) I have no idea. My AIW cards all included a remote which was useless because I need to change channels at the sat box.
    5) No idea.
  2. copy/past this into videohelp.com forums to get 10,000 users with answers...
    Hide
  3. I don't have the dual tuner 500, but I have the single tuner version the pvr150. I will try and describe those points of my setup that might help you.
    I have sattellite and connect the decoder box to the tuner via svhs cable. The Ir blaster software changes the channels on the decoder box and the remote works great.
    If I had dual tuners and cable, I would set one tuner on the cable box for channels that must be descrambled (using svhs input), and I would splitter the cable to the other tuner to capture unscrambled channels.
    I have a dual core opteron 165, and it works GREAT!!!! I have heard rumors of people with problems, but I don't have them. I am running on W2000 atm. I expect if there are problems with dual cores, it is specific to windows MCE, or possibly a VIA chipset.
    I am still auditioning the various software packages, but so far BeyondTV is giving me the least headaches, and it takes advantage of the dual cores very nicely.
Tuner Cards TV Tuner Graphics
