Archived from groups: microsoft.public.windowsnt.terminalserver.connectivity (More info?)
how come pcanywhere fails to work correctly after i have used a remote
desktop session since last reboot? pcanywhere just shows a black screen with
a curssor blinking in the top left corrner.
I'm amazed that you can connect at all. When you install pcAnywhere,
it replaces the normal msgina.dll with awgina.dll. It warns you about
this during installation.
pcAnywhere and TS on the same box don't mix well.
Vera Noest
MCSE, CCEA, Microsoft MVP - Terminal Server
http://hem.fyristorg.com/vera/IT --- please respond in newsgroup, NOT by private email ---
"James" <See.My.Sig@The.Bottom.com> wrote on 29 sep 2004 in
microsoft.public.windowsnt.terminalserver.connectivity:
> remote desktop session since last reboot? pcanywhere just shows
> a black screen with a curssor blinking in the top left corrner.
i didn't get that error message. im not using the full terminal server, just
remote desktop on xp. and it does work as long as i don' t remote desktop
before i use pcanywhere. seems like remote desktop IS breaking pcanywhere.
"Vera Noest [MVP]" <vera.noest@remove-this.hem.utfors.se> wrote in message
news:Xns9574CE05745D6veranoesthemutforsse@207.46.248.16...
> Vera Noest
> http://hem.fyristorg.com/vera/IT > --- please respond in newsgroup, NOT by private email ---
Well, let's not argue about what breaks what. pcAnywhere replaces
the standard login software msgina.dll with awgina.dll, and the
two of them are not compatible.
Normally, it is rdp that stops functioning.
Vera Noest
"James" <See.My.Sig@The.Bottom.com> wrote on 30 sep 2004 in
> server, just remote desktop on xp. and it does work as long as i
> don' t remote desktop before i use pcanywhere. seems like remote
> in message
>> pcAnywhere, it replaces the normal msgina.dll with awgina.dll.
>> It warns you about this during installation.
>> Vera Noest
>> http://hem.fyristorg.com/vera/IT >> --- please respond in newsgroup, NOT by private email ---
>>> a remote desktop session since last reboot? pcanywhere just
>>> shows a black screen with a curssor blinking in the top left
>>> corrner.
> Vera Noest
