Is Remote Desktop Connection Login secure over wireless?
  • Remote Desktop
  • Connection
  • Microsoft
  • Windows
Last response: in Windows 2000/NT
Anonymous
July 16, 2005 5:26:37 PM
Archived from groups: microsoft.public.windows.server.security,microsoft.public.windowsnt.terminalserver.connectivity,microsoft.public.windowsnt.terminalserver.protocols.rdp (More info?)
Greetings experts!
When I am using free public wireless hotspots such as coffee-houses, etc.,
the security warning indicates that the connection is not secure, and I
understand that (essentially :)
My question is: If I use an un-secured wireless network connection, then
attempt to use Windows Remote Desktop Connection to connect to my PC at
home, is the username and password I type into the Remote Desktop Connection
settings encrypted or otherwise protected? Or am I at risk of hackers
intercepting the login credentials I pass to RDC?
Thanks!
More about : remote desktop connection login secure wireless
Anonymous
July 16, 2005 8:28:58 PM
The secure tunnel is created before you enter your credentials and even then
your password is never sent over the network. However I would never enter my
credentials on a public kiosk computer or other computer that I do not know
is secure/clean. From your description it sounds as if you are using your
own laptop. --- Steve
"Mark Findlay" <mfindlay@speakeasy.org> wrote in message
news:%23ZSCsSkiFHA.500@TK2MSFTNGP09.phx.gbl...
> Greetings experts!
> Connection settings encrypted or otherwise protected? Or am I at risk of
> hackers intercepting the login credentials I pass to RDC?
> Thanks!
Anonymous
July 17, 2005 8:00:48 PM
Thanks Steve,
Just to clarify my understanding: the "secure tunnel" you refer to - that's
something that RDC creates automatically on my behalf? In other words, there
are no special configurations or special connection settings I need to
create on my laptop or the target PC? I only ask since I had seen some
references in other postings to private VPN etc., and I don't have any of
that set up. I am just using the default installations of XP on both laptop
and PC.
If there are any special configuration steps I need in order to establish
the "secure tunnel", could you elaborate on those?
Many thanks!
Mark
"Steven L Umbach" <n9rou@nospam-comcast.net> wrote in message
news:eIHF00kiFHA.2644@TK2MSFTNGP09.phx.gbl...
> then your password is never sent over the network. However I would never
> enter my credentials on a public kiosk computer or other computer that I
> do not know is secure/clean. From your description it sounds as if you are
> using your own laptop. --- Steve
>> Greetings experts!
>> etc., the security warning indicates that the connection is not secure,
>> and I understand that (essentially :)
>> Thanks!
Anonymous
July 17, 2005 11:21:13 PM
Remote Desktop establishes the tunnel before you logon. You do not have to
do anything special. Just make sure you use real strong passwords on your
computer as others most likely attempt to logon also when they see port 3389
TCP open on your computer. I would also enable auditing of logon events in
Local Security Policy so that you can keep track of such. If you find an
abuser you could try to configure your firewall or ipsec filter to block
access from that persons public IP address. --- Steve
news:eMA8jNyiFHA.1412@TK2MSFTNGP09.phx.gbl...
> Thanks Steve,
> that's something that RDC creates automatically on my behalf? In other
> words, there are no special configurations or special connection settings
> I need to create on my laptop or the target PC? I only ask since I had
> seen some references in other postings to private VPN etc., and I don't
> have any of that set up. I am just using the default installations of XP
> on both laptop and PC.
> Many thanks!
> Mark
>> are using your own laptop. --- Steve
>>> Greetings experts!
>>> Thanks!
Anonymous
July 18, 2005 2:48:14 PM
Hi,
If I may add, just double check on Terminal server that the Encryption Level
is set to at least High.
For added security you could also add TLS to prevent e.g.
"man-in-the-middle" attacks...
How to configure a Windows Server 2003 terminal server to use TLS for server
authentication
http://support.microsoft.com/?id=895433
Mike
Microsoft MVP - Windows Security
news:%23b%23v05yiFHA.3656@TK2MSFTNGP09.phx.gbl...
> to do anything special. Just make sure you use real strong passwords on
> your computer as others most likely attempt to logon also when they see
> port 3389 TCP open on your computer. I would also enable auditing of
> logon events in Local Security Policy so that you can keep track of such.
> If you find an abuser you could try to configure your firewall or ipsec
> filter to block access from that persons public IP address. --- Steve
>> Thanks Steve,
>> Many thanks!
>> Mark
>>> I do not know is secure/clean. From your description it sounds as if you
>>>> Greetings experts!
>>>> then attempt to use Windows Remote Desktop Connection to connect to my
>>>> PC at home, is the username and password I type into the Remote Desktop
>>>> of hackers intercepting the login credentials I pass to RDC?
>>>> Thanks!
Anonymous
July 18, 2005 2:48:15 PM
Thanks for that info Mike. In this case I believe the user is probably using
XP Pro [home pc mentioned]. If that is the case he still could use local
Group Policy to make sure default high encryption is enforced by going to
computer configuration/administrative templates/Windows components/terminal
services/encryption and security. --- Steve
"Miha Pihler [MVP]" <mihap-news@atlantis.si> wrote in message
news:uby9wV3iFHA.3692@TK2MSFTNGP09.phx.gbl...
> Hi,
> Level is set to at least High.
> server authentication
> Mike
>>> Thanks Steve,
>>> settings I need to create on my laptop or the target PC? I only ask
>>> since I had seen some references in other postings to private VPN etc.,
>>> and I don't have any of that set up. I am just using the default
>>> installations of XP on both laptop and PC.
>>> establish the "secure tunnel", could you elaborate on those?
>>> Many thanks!
>>> Mark
>>>> never enter my credentials on a public kiosk computer or other
>>>> computer that I do not know is secure/clean. From your description it
>>>> sounds as if you are using your own laptop. --- Steve
>>>>> Greetings experts!
>>>>> secure, and I understand that (essentially :)
>>>>> Desktop Connection settings encrypted or otherwise protected? Or am I
>>>>> at risk of hackers intercepting the login credentials I pass to RDC?
>>>>> Thanks!
Anonymous
July 18, 2005 8:48:08 PM
Correct, thanks Steve for the added info.
For anyone else reading, I also changed the default port that RDC listens on
so that hackers trying 3389 would fail.
Thanks!
Mark
news:eWZCPk3iFHA.1232@TK2MSFTNGP15.phx.gbl...
> using XP Pro [home pc mentioned]. If that is the case he still could use
> local Group Policy to make sure default high encryption is enforced by
> going to computer configuration/administrative templates/Windows
> components/terminal services/encryption and security. --- Steve
>> Hi,
>> Mike
>>> such. If you find an abuser you could try to configure your firewall or
>>> ipsec filter to block access from that persons public IP address. ---
>>> Steve
>>>> Thanks Steve,
>>>> Many thanks!
>>>> Mark
>>>>> even then your password is never sent over the network. However I
>>>>> would never enter my credentials on a public kiosk computer or other
>>>>>> Greetings experts!
>>>>>> my PC at home, is the username and password I type into the Remote
>>>>>> Thanks!
Anonymous
July 19, 2005 2:22:52 AM
Microsoft just released an advisory that Terminal Services (RDP) are
vulnerable to a Denial of Service attack.
http://www.microsoft.com/technet/security/advisory/9047...
This doesn't have anything to do with wireless, over which you are just as
secure as any other medium. However, you'll want to know about this.
Chris
news:esNQpM$iFHA.3436@tk2msftngp13.phx.gbl...
> on so that hackers trying 3389 would fail.
> Thanks!
> Mark
>>> Hi,
>>> Mike
>>>> have to do anything special. Just make sure you use real strong
>>>> passwords on your computer as others most likely attempt to logon also
>>>> when they see port 3389 TCP open on your computer. I would also enable
>>>> auditing of logon events in Local Security Policy so that you can keep
>>>> track of such. If you find an abuser you could try to configure your
>>>> firewall or ipsec filter to block access from that persons public IP
>>>> address. --- Steve
>>>>> Thanks Steve,
>>>>> etc., and I don't have any of that set up. I am just using the default
>>>>> Many thanks!
>>>>> Mark
>>>>>>> Greetings experts!
>>>>>>> I at risk of hackers intercepting the login credentials I pass to
>>>>>>> RDC?
>>>>>>> Thanks!
November 15, 2006 3:07:59 PM
Hi!
I found this thread searching the net for info on RDP encryption, you seem to have a lot of knowledge about this so I'll just fire away som questions and hope you'll have some answers.
1. I've heard that the RD encryption isn't activated until after you've logged in to the remote computer (thus sending login info uncrypted), this sounds quite strange (stupid even) and I wonder if there's any truth to it?
2. I'm on WinXP (both remote and local) and changed the "Set client connection encryption level" in the Group Policy editor to Enabled, is this something that only has to be done on the server? I also heard that default encryption is always activated in RD, but my (old (original)) group policy begged to differ...?
3. Even though I changed the group policy (and heard that this shouldn't have to be done since it's active by default) the registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Terminal Server\Wds\rdpwd\fDisableEncryption is set to 1, what does this mean?
4. (The bonus question)
After reading this thread about connecting over unsecure wireless networks I just wonder: when RD connects to the server and activate the encryption I guess som key negotiation is done between the two sides. Wouldn't it be possibe to sniff this negotiation and get the needed info to decrypt all other data?
Ok, that's it. Grateful for any answer!
Best Regards
Kristoffer
November 16, 2006 1:47:41 PM
the RDP encryption methods are for the duration of the RDP session, not for authentication
authentication is a different story, they have different algorithims and it's not an unecrypted / clear text password, it will use either kerberos or ntlm just like when you login to a workstation, it's encrypted
you could tighten up your wifi if you're worried about sniffers when you're entering credentials, but the default encryptions are pretty good and not easy to sniff
not to mention you can have certificates for authentication as well in terminal services
November 30, 2009 10:19:11 AM
Quote:
Greetings experts!
Thanks!
Yes, your asking for trouble. RDP is vulnerable to Man In The Middle attacks.
http://www.securiteam.com/windowsntfocus/5EP010KG0G.htm...
Quote:
Steve said...
"The secure tunnel is created before you enter your credentials and even then
your password is never sent over the network."
How is the client authenticated if credentials are not passed over the network?
Once again check this...
Quote:
If you find an
A slightly better way would be to block all IP addresses except the ones you explicitly want to allow.
In saying this, IP addresses can be spoofed.
Quote:
Mark stated... "For anyone else reading, I also changed the default port that RDC listens on
so that hackers trying 3389 would fail."
Hackers only searching for a specific port are not really hackers.
A packet sniffer will disclose an RDP session by the T.125 protocol.
Once an attacker has got access to your wired network or an unsecured wireless network,
All they need to do is run a packet sniffer, find out the IP addresses being used in the RDP session and launch a MITM attack.
The attack described above has been successfully implemented into the software Cain & Abel available at
http://www.oxid.it. From version 2.7 the program can now perform man-in-the-middle attacks against RDP
protocol sessions decrypting all the information that travels from client to server in both directions. The
program try also to recognize the keyboard activity at the client-side providing some kind of password
interception.
