Problem with connecting using Citrix client into w2k3 serv..
Ed
1,253
Archived from groups: microsoft.public.windowsnt.terminalserver.connectivity (More info?)
When I connecting using Citrix client via internet to windows 2003 server, at
logon screen popup next two messages :
1.
Connection Error
The desktop you are trying to open is currently available only to
administrators. Contact your administrator to confirm that the correct
settings are in place for your client connection.
2.
Logon Message
To Log on to this remote computer, you must have Terminal Server User Access
permissions on this computer. By default, members of the Remote Desktop Users
group have these permissions. If you are not a member of the Remote Desktop
Users group or another group that these permissions, or if the Remote Desktop
User group does not have these permissions, you must be granted these
permissions manually.
I`m in group remote desktop user group too.
Where is problem ? How permission haven`t ?
G
Guest
Guest
Are you trying to connect to the desktop of the server? Have you
published the desktop?
Check this:
CTX104106 - Connection Error : The desktop you are trying to open
is currently available only to administrators
http://knowledgebase.citrix.com/kb/entry.jspa?externalID=CTX104106
_________________________________________________________
Vera Noest
MCSE, CCEA, Microsoft MVP - Terminal Server
TS troubleshooting: http://ts.veranoest.net
___ please respond in newsgroup, NOT by private email ___
"=?Utf-8?B?ZWQ=?=" <ed@discussions.microsoft.com> wrote on 28 sep
2005 in microsoft.public.windowsnt.terminalserver.connectivity:
> 2003 server, at logon screen popup next two messages :
> 1.
> Connection Error
> to administrators. Contact your administrator to confirm that
> the correct settings are in place for your client connection.
> 2.
> Logon Message
> User Access permissions on this computer. By default, members of
> the Remote Desktop Users group have these permissions. If you
> are not a member of the Remote Desktop Users group or another
> group that these permissions, or if the Remote Desktop User
dedys
I had same problem with the same error message. But the deferent is my user logon to server using the terminal server and login as user. How can I solve this issue ???
For the info, I installed the License Server on my DC and 150 CAL activate, and I had the 10 Servers with Terminal Server installed at the same Domain.
Best regards for the solutions.
