Need Help
Forum CPU & Components : CPUs - Need Help
What is best
P 650 3.4GHz S775/800/2MB cache 64-BIT
or
CPU AMD ATHLON 64 3500+ Venice
Sponsored Links
in this current generation of CPU's
I'd believe youd' get better performance out of the ATHLON 3500+. what exactly though is your intended use of the computer?
currently the ATHLONS are better "bang for the buck" with their fast onchip memory controller, low Thermal disapation, and higher FSB (hyper transport).
the AMD's memory controller is really fast and is able to perform very well with DDR400 ram and still keep neck to neck with the DDR2 memory intel uses.
the thermal disapation is far lower. Intel's CPU's average heat loss is supposed to be around 115w to 135w while the AMD's maximum is around 115w. both CPU's come with adequate boxed coolers though.
and AMD CPU's now use what they call "Hyper Transport Tunnel" or HTT. this is there version of the "front side bus" and it runs at 1,000mhz aposed to intel's 800mhz. This allowing for more bandwith to the CPU.
all combined, as i said the AMD Athlon would probably provide for greater performance now.
but this only applies to the CURRENT GENERATION CPU's. in the future generation, intel has a few promising tehcnologies that "COULD" be better than AMD's. although AMD will be releasing a few of their own
but the low down is both CPU's are good CPU's and will perform whatever tasks you give them
Reply to mpasternak
I would say, for just about any task you could throw at those two procs, AMD will come out on top.
Reply to slvr_phoenix
Tom's Hardware > Forum > CPU & Components > CPUs > Need Help
There are 1123 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
