Archived from groups: microsoft.public.win95.general.discussion (
More info?)
<sigh> I forgot I was in a Win95 group.
No, there is no easy way to do a clean boot in Win95, as there is no System Configuration Utility (msconfig.exe) in Win95....although msconfig.exe from Win98 will work in Win95 also, if added to the Windows folder.
Does the system start in Safe Mode?
If so, follow the procedures here -
Troubleshooting Windows 95 Using Safe Mode:
http://support.microsoft.com?kbid=156126
How to Troubleshoot Windows Protection Error Messages:
http://support.microsoft.com?kbid=149962
You can also try a Step-by-Step Confirmation boot, to try and determine what is causing the error....often it is a driver problem.
Using Microsoft Windows' Startup Modes For Troubleshooting:
http://www.rlrouse.com/windows-startup-modes.html
Did you add or change something just prior to this happening?
Glen Ventura, MS MVP W95/98 Systems
http://dts-l.org/goodpost.htm
<bchcomer2001@yahoo.com> wrote in message news:k2pl70tdf48u1bh9jsonb75i2j11agmh5h@4ax.com...
> Your instructions are for W98? Can they also be used for W95?
> Thank you
> On Wed, 7 Apr 2004 23:12:49 -0400, "glee" <glee29@spamindspring.com>
> wrote:
> >Let it start in Safe Mode, then follow the procedure here to do a clean boot, to try to determine what is causing the problem:
> >How to Perform Clean-Boot Troubleshooting for Windows 98
> >http://support.microsoft.com?kbid=192926
> >"CLEAN BOOT -- What it is and why you need it." by MS MVP Gary Terhune
> >http://www.google.com/groups?selm=%23q4I1qNODHA.2096%40TK2MSFTNGP12.phx.gbl
