Tom's Hardware > Forum > CPU & Components > Other Components > USB Serial Adapter problems
Forum CPU & Components : Other Components - USB Serial Adapter problems
My Dell does not have a D-9 port so I am trying to use a USB Serial Adapter (CP-US-03, http://www.cptechusa.com/cgi/produ [...] t=3&sc=30) made by CP Technologies.
I uninstalled the software (BoxCar Pro 4.3) I am using, uninstalled the driver (by Prolific), and restarted... then installed the software, plugged the device in, and let XP install the driver.
In the device manager the port is listed as "GM USB-to-Serial (COM4)." When I try to connect to the device (logger) through COM4 the software says: Logger not found. Your logger may not be hooked up correctly, you chose the wrong communictions port, your serial cable may be faulty..."
Any suggestions on anything? Would it help to change the settings for "Data bits, Parity, Stop bits, Flow Control" and if so, is it a stab in the dark or is there a way to make an educated guess.
Also, I just realized the company, OnSet (www.onsetcomp.com) sells and suggests using this adapter (http://www.keyspan.com/products/usb/USA19HS/).
Is there that big of a difference? Why would two adapters be that different? Isn't there a way to configure my adapter to work like the Keyspan adapter?
Thanks in advance
Sponsored Links
really? no insight from tomshardware forum? this forum was able to answered all of my questions in the past.
what is this world coming to?
Reply to zargian
There are 1306 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
