Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Missing "decpw386" problem - Need a fix
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Missing "decpw386" problem - Need a fix
Archived from groups: comp.os.ms-windows.win95.setup,comp.os.mswindows.networking.win95,microsoft.public.win95,microsoft.public.win95.general.discussion,comp.os.mswindows.setup.win95 (More info?)
Greetings -
Well I have Googled all over and cannot find a fix that works. This
appears to have been a well-documented problem early on with Win95.
I was forced to format the drive and reinstall Windows 95, a custom
NEC job with a special system software restoration CD. It all went
well until I was setting up my ethernet card (Belkin).
I accidently selected and "installed" one of the Dec Pathworks
Ethernet options. When I realised that this was not right, I went to
the Network panel and removed it.
However, during the boot I now get an error saying the "decpw.386" is
missing. The boot stalls there waiting for any key to be pressed to
bypass the error. It alkso suggests removing the program (done) or
editing SYSTEM.INI.
Of course, the only problem is that SYSTEM.INI has no refrence to this
missing file.
Dones anyone know of a Windows patch that will fix this that is still
available for download? Or is there something I can add to SYSTEM.INI
to trick it into thinking its there?
Or does anyone have a copy of "decpw.386" they can send me and tell me
where to install it to get this error to go away.
DMK
Sponsored Links
If decpw.386 does not appear anywhere in your System.ini file (or win.ini), search
the Registry for a reference to it.
Start>Run>Regedit> Edit menu> Find, search for decpw.386 and post back with exactly
what you find.
Be sure to back up the Registry before editing it. Go to C:\Windows and COPY these
two files to another folder: System.dat and User.dat
Glen Ventura, MS MVP W95/98 Systems
http://dts-l.org/goodpost.htm
"D. Kirkpatrick" <sunclad@sunclad.com> wrote in message
news:sunclad-24A8A5.03163421062004@news.verizon.net...
> Greetings -
> editing SYSTEM.INI.
> missing file.
> DMK
Reply to Anonymous
There are 1275 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
