Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Potential problem with XP SP2
Archived from groups: microsoft.public.windowsxp.basics (More info?)
Hi
I notice that one of the fixes in sp2 is the installation of the advanced
networking pack. I installed this a while ago and had quite a problem. When I
connected to the internet my pc froze for 5 minutes (after that it ws fine).
A pleasent chap from the online support team tracked the problem down to this
pack and helped me disable it (I couldn't uninstall it using add/remove
programs in control panel - don't know why the chap from Microsoft said
don't).
I presume that I will have the same problem after installing SP2?
I have a HP pavilion 423.uk with 1GB ram 1.8ghz Celeron and a wife who would
prefer a new washing machine to a PC
Sponsored Links
Open control-panel or/and insert xp cd,select windows components,open
networking services,chk all,then close-out.Then go to run,type:cmd In cmd
type:ipv6 install When its thru type:EXIT Restart computer.
"tom_the-confused" wrote:
> Hi
> don't).
Reply to Anonymous
You might also open internet connections,select or have only:Client for
Microsoft
Networks,Internet Protocal,and Microsoft TCP/IP6 Packet scheduling delete or
uninstall,and others do the same for.
> Hi
> don't).
Reply to Anonymous
I went through this with the support guy - his advice was to disable it -
which as my pc is running fine is what I'll probably do
> Microsoft
> > Hi
> > don't).
Reply to Anonymous
There are 1142 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
