For example, I have a PC Power & Cooling 850, and it comes with 2 lines with the 6pin SLI power fittings, but the 6pin fitting wont fit into the the 7800GTX KO's 6pin slot. I had to use the 6pin adapter that came with the GTXs and plug them in with the 2 molex connectors. Whats the deal? Anyone else have any issue with that, or are you suppose to use the little adapter that comes with vid card instead of using the "SLI" cables from power supply.
