Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Help! Floppy drive refuses to read diskettes
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Help! Floppy drive refuses to read diskettes
Archived from groups: microsoft.public.win95.general.discussion (More info?)
Okay
Suddenly, messages such "device is not ready" or "this
disk is not formatted, do you want to format it now"
started to appear when I insert floppy disks in the drive
A:
Worst thing the device manager won't let me to delete A:
dirve controllers (standard generic drivers) so Windows
can re-detect hardware as suggested here:
http://support.microsoft.com/default.aspx?scid=kb;en-
us;131690
Strange thing is why Windows won't let me delete current
drivers!!! it displays a message such "select + to
display a list of available drivers for this device"
though I select right controller (expand all drivers).
I made every suggestion from link above with no results
and I'm start guess with proper device failure.
This is a 6 years old IBM 350 model refurbished, Pentium
processor, 48 MB RAM, 2.1 GB HD, NEC floppy drive device.
P.S. I noticed 2 identic generic drivers duplicated
under "floppy disk controllers" in Device Manager.
Please help
Dale
Sponsored Links
"Dale" <anonymous@discussions.microsoft.com> wrote in message
news:293e01c4a2bb$893013f0$a401280a@phx.gbl...
> Okay
> A:
> us;131690
> Please help
> Dale
shutdown and restart in dos
if the drive still does not work...it is simply bad
Reply to Philo
Restart in Safe Mode:
-Start the computer, and as soon as you see the words "Starting Windows 95...",
repeatedly tap the F8 key till the Windows 95 Startup menu (boot menu) appears.
-Use the arrow keys to select "Safe Mode" and press Enter.
In Safe Mode, open Device Manager.
Expand the Disk Drives category, and remove the floppy disk drives listed there.
Expand the Floppy Disk Controllers category and remove all floppy controllers
listed.
If it exists, expand the "Other" devices category, and remove everything there.
Click OK/Close, then click Start> Shutdown> Restart, to start in normal mode and let
Windows detect the devices.
Glen Ventura, MS MVP W95/98 Systems
http://dts-l.org/goodpost.htm
> Okay
> A:
> us;131690
> Please help
> Dale
Reply to Anonymous
>Please help
>Dale
Hi!
Try booting your pc with a startup floppy to verify that
drive still works. If so, run regedit.Go to
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\FDC and
look for duplications.Alternativly boot pc to safe mode.
Remove all instances of generic floppy from device manager.
Please reply
Christo
Reply to Anonymous
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
