So when I connect my surroundsound headset to my front panel soundjack I get reversed sound playback, ie: Front is back and left is right. This IS very confusing when playing my Fav FPS's and I cant just flip my headset around because then I cant use the mic on it.
Im using an MSI Neo3 mobo with Realtek AC97 integrated audio.
I already tried opening up my box, and flipping the connection on the mobo to the front soundjack that resulted in no change. So I downloaded the new drivers from realtek site and still no change.
Im hoping someone here has had this problem before and knows what to do...
dont know if this helps but the rear soundjack only has playback in the left ear.
Ok.. so its not 1. and im pretty sure its not 2. but let me just make sure,
The audio ports on that plug into the motherboard is the square black piece of plastic about 1/2 inch in size and has Speaker written in white on it ? Usually a black and red wire attached? If this is it then I have already flipped it around and plugged it in the other way, to no avail.
