Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Week 5 Problem (Updated Punctuation)
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Week 5 Problem (Updated Punctuation)
Archived from groups: microsoft.public.win95.general.discussion (More info?)
Trying to get help for this frustrating situation.
Lord if you just help me out of this one I will never be bad again and
try doing stuff I know little or nothing about.
I promise Lord please please...
My system was running just fine but was really slow and would
occasionally hang unexpectedly.
It is a pentium 133, w95b.
It easily formatted before with the self starting oem w95 cd.
But this time I have partitioned the drive and set one drive active as
per the prompts.
The c drive I formatted from the bios first, kind of by accident using
the low level performat function.
When I clicked on that a warning prompt said 'all info on this drive
will be lost'.
At this point I thought here is
how the pros must format hard drives quickly and easily, so I pressed
on.
It only took a few seconds I think.
Now when I put the w95 cd in and restart the system the setup feature is
not auto-run and I receive the prompt 'invalid system disk'.
I now put in the system floppy start up
disk.
I now receive prompt 'remove all disks and press any key to
continue'.
When I press any key I just get the a:prompt.
I was told to partition and format the hard drive so I did that.
I was told to add a line to config and autoexec files either on hard
drive or the system start up disk regarding the cdrom drivers.
I did that but still no luck.
Now I get the prompt that my config file are corrupt in the first
line.
I was thinking, (I could be dangerous ha ha), that I have the
setup w95 cd that I know works fine and I have the key for that as well,
all legitimate.
I have had this system for about 6 years now since brand
new.
I thought I could put the w95 cd on floppies but over fifty would
be needed to do this.
One of the other prompts I get when at the a:prompt and I try to boot
the setup from cdrom, is 'cd01 not done reading yet'or something like that.
So the real problem is the preformat cleared everything from drive c I
know that now.
So how do I get the proper config and autoexec files onto drive c so it
can read cdrom and begin setup of w95?
Sure I am no expert nor do I claim to be one but someone must know if it
is futile to continue this in this loop or is that I am simply missing
an entry or some simply tweak too get w95
loaded and started on this system.
Sorry for the long explanation, but if anyone can help me it is best to
have all the info possibly available so I hope someone can cut through
all this and kindly guide me in the right direction even if that means
to scrap the system.
If no one here can help me I would much appreciate that truth rather
than trying another idea shot in the dark so to speak that further
aggravates the situation as changing the config line has done.
The reason I believe for this help board and others is to help people
who don't know anything to get the help they need.
As opposed to being led down the proverbial garden path.
Here a tip but if you don't know what your doing well if you mess up you
only have your self to blame.
So many folks the world over may be taking advice here rather naively
and messing up their system totally, then scraping them only to purchase
new systems with microsoft software on it.
More money for microsoft and the computer industry.
Is this a microsoft board and is the advice free?
Well folks you get what you pay for.
Maybe I am wrong but many folks including myself want to believe
the help here is genuine through and through but I feel I wasn't help
resolve my problem at all only that I am more confused now than when I
first posted for help.
It sound like I have an ax to grind and maybe that is true.
But I feel folks have more important things to do than get the run
around online when sincerely needing help.
At least I am for one.
I must confess it hasn't been a total waste of my time though.
On the bright side I read oodles of info on bootdisk.com and here.
So maybe if I decide somewhere along the line to get into computers and
become a PC Tech this experience will have been helpful.
In the meantime though I am just hanging as to what to do next here.
Sorry Lord I got diarrhea of the keyboard.
I hope someone here is not afraid to take the time and help me resolve
this problem in a positive and timely fashion. Thank you Lord.....Bryan
Sponsored Links
You used the BIOS low-level format option which no longer appears in current
BIOSes.
You have undoubtedly screwed the hard drive up by doing that. If you want it
fixed, send it to the manufacturer. It will be much more expensive than
buying a new drive.
Excelstore drives are excellent, but you can get new drives very
inexpensively that will still run at the ATA33 speed that your system uses.
Eric,
http://www.pcbuyerbeware.co.uk/
http://www.sharedbirthday.co.uk/
Excelstor Hard Disk Drives: Google Search: http://tinyurl.com/5a3ku
> per the prompts.
> will be lost'.
> on.
> disk.
> continue'.
> line.
> all legitimate.
> new.
> know that now.
Reply to Eric
There are 1286 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
