Archived from groups: microsoft.public.win95.general.discussion (More info?)
Have a W95 machine cabled to Linksys router. It previously connected to the
internet without problem. Recently, it lost the internet connection, though
the other computer on the network has internet connection.
Did a ping 127.0.0.1 and it failed. Went to uninstall and reinstall TCP/IP,
but there was no listing under network properties, so it was somehow lost?
Anyway, following some procedures I found, I renamed vip, vnbt, vtcp, vtdi
and vdhcp from xxx.386 to xxx.old. Then added the TCP/IP using the network
properties boxes.
The first time, it started finding files on my W95 disk and telling me there
was a newer file on the computer and I should keep it. Did for all files
(about 6 or 8 of them). When it seemed to be done or almost done it stopped
running and gave an error. Had to start in safe mode.
Tried all again, got this message, "A fatal exception 0D has occurred at
0028:C1097FE5. The current application will be terminated."
Changed to standard VGA driver, didn't help.
Finally uninstalled and installed TCP/IP, this time taking the old files
from CD rather than the newer files. It ran throught the procedure fine,
restarted, windows came up--but same situation, no connection to internet, no
loopback success w ping 127.0.0.1. When I look now in network properties,
TCP/IP is there.
Any suggestions?
Larry
Sponsored Links
"LarryM" <LarryM@discussions.microsoft.com> wrote in message
news:1F90DE13-8A1A-440A-843F-9DFA9136D4F8@microsoft.com...
> the
> though
> TCP/IP,
> properties boxes.
> there
> stopped
> no
> TCP/IP is there.
> Any suggestions?
> Larry
try this ...
http://www.bu.edu/pcsc/internetaccess/winsock2fix.html
Reply to HAGGIS
> > the
> > though
> > TCP/IP,
> > properties boxes.
> > there
> > stopped
> > no
> > TCP/IP is there.
> > Any suggestions?
> > Larry
> try this ...
The above program only works for Windows 98, not 95.
If you are using a Firewall, check to make sure that it isn't set to block
Internet Access.
Eric,
http://www.pcbuyerbeware.co.uk/
http://www.sharedbirthday.co.uk/
Reply to Eric
"Eric" <Eric@discussions.microsoft.com> wrote in message
news:DC3F498F-ECED-471F-BED9-27A938310696@microsoft.com...
>> > the
>> > though
>> > TCP/IP,
>> > lost?
>> > vtdi
>> > network
>> > properties boxes.
>> > there
>> > files
>> > stopped
>> > at
>> > files
>> > fine,
>> > internet,
>> > no
>> > properties,
>> > TCP/IP is there.
>> > Any suggestions?
>> > Larry
>> try this ...
> Internet Access.
> Eric,
oops , you're right Eric (must wake up before reading :> ) thks
still think the winsock has been corrupted from what he says about trying to
in stall...maybe install winsock2 from here ?
http://www.microsoft.com/windows95 [...] efault.asp
watch the word wrap
Reply to HAGGIS
Haggis and Eric,
Thanks! Worked perfectly when I downloaded the winsock2 fm MS.
Larry
Reply to Anonymous
good to hear :>
news:D3073E38-C3E6-4A3D-8889-06E17E10EAF7@microsoft.com...
> Haggis and Eric,
> Larry
Reply to HAGGIS
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Problem with TCP/IP
There are 1302 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
