Archived from groups: microsoft.public.win95.general.discussion (More info?)
This may be a really dumb question.
I have an old timer I use a logging box, and once in a while it pops the RHP
dialog.
Unfortunately, W95 doesn't give any other clues as to just what the problem
is, and due to it's infrequent nature I haven't been having a lot of luck
tracking it down.
I haven't seen this particular problem, but there is a good description of
the RHP dialog here (you have to hunt back and forth through the tutorial),
although what it has to do with logging I don't understand.
http://www.whiterockscience.com/moritz/surf_body.html --
Jeff Richards
MS MVP (Windows - Shell/User)
"Alinator" <twpi@att.net> wrote in message
news:xLcId.62259$w62.28003@bgtnsc05-news.ops.worldnet.att.net...
> RHP
> dialog.
> problem
> tracking it down.
> Any thoughts?
> Alinator
"Jeff Richards" <JRichards@msn.com.au> wrote in message
news:eQu#hXNAFHA.3504@TK2MSFTNGP12.phx.gbl...
tutorial),
> http://www.whiterockscience.com/moritz/surf_body.html > --
> Jeff Richards
All I meant was this box is used for logging purposes, and only has a few
usually well behaved utilites installed and not the typical hodgepodge of
apps on board.
I think I've narrowed it down to some kind of interaction between Kiwi
syslog and W95, but the strange thing is on it's "twin" this doesn't happen!
I've got Sysinternals Regmon running on it now, but of course it has chosen
to behave itself for the time being. ;-)
Thanks for the link, I'll root around there to see if I can get some further
insight into what's going on.
"Alinator" <no-twpi-junk@att.net> wrote in message
news:T5RId.74112$w62.67116@bgtnsc05-news.ops.worldnet.att.net...
of
> tutorial),
<snip>
I think you misunderstood me.
RHP = Win 95's "Registry Has a Problem" dialog box in this case.
I poked around on the link you gave me and didn't find any references to
registry troubleshooting.
So are you saying that the RHP dialog you are seeing is not the one you use
to manipulate the properties of a right hexagonal prism drawing surface?
What is the exact wording that appears in this dialog?
Jeff Richards
news:qc_Id.18682$8u5.12421@bgtnsc04-news.ops.worldnet.att.net...
> of
>> tutorial),
> <snip>
> Alinator
news:uJOKwkcAFHA.3744@TK2MSFTNGP15.phx.gbl...
use
> Jeff Richards
Sorry for the confusion, I'm not even running that software package.
Basically I'm using this machine to monitor and record log messages on my
LAN. I think it's related to Kiwi Syslog, but am not 100% sure.
The problem is every so often 95 pops up a dialog box (during a long uptime
run)saying a problem has been encountered with the registry, and the only
option is a "Restart Windows" button. Interestingly, everything seems to
continue to function normally (except I can't close the bloody dialog).
I'm in the process of a step by step test of each utility I use on this
machine, after performing a clean reinstall and patch of 95.
It's just I had never seen this dialog before (except for a corrupt registry
at boot), and the subsequent reboot is normal with no errors.
I was just looking to see if anyone might have some tips about likely causes
to investigate, since 95 is being pretty tight lipped about what the exact
problem is.
If the dialog box refers to the Windows registry and not the TS registry,
then the most likely cause by far is a RAM problem, Windows is continually
examining and testing the registry, and an error in RAM will create exactly
the message you are seeing. Actually, I guess it would be the same for the
TS registry as well. The fact that it occurs randomly supports this, as does
the ability to re-boot OK. The dialogue locking while the application itself
continues to run OK is also consistent with a RAM problem.
The usual fix for an intermittent RAM problem is to (carefully) remove and
re-seat the RAM modules. You might get some diagnostic confirmation by
re-arranging things, such as what software applications you run or the order
in which they load. If the problem changes but occurs with about the same
frequency, this suggests RAM. Has the operating environment recently warmed
up, or is the problem evident on warm days? A RAM diagnostic will also
often help.
Jeff Richards
news:hW%Id.18998$8u5.1800@bgtnsc04-news.ops.worldnet.att.net...
> use
>> Jeff Richards
> uptime
> registry
> causes
> problem is.
> Alinator
news:ePUcIEeAFHA.2572@tk2msftngp13.phx.gbl...
continually
exactly
the
does
itself
order
warmed
> often help.
> Jeff Richards
<snip>
Jeff,
Thanks for your input.
The concensus overall, is this is looking to be a hardware related issue. So
I've set the machine up with my logging voltmeter on the PS, cleaned and
reseat the RAM sticks, and am doing a long term RAM diagnostic run.
Contrary to what a lot of people believe, things do happen in Windows due to
cause and effect relationships, after if you take the time you can track it
down. :-)
