Can't VPN using WIFI please help!
Forum General Networking : VPN, VoIP, Video Conferencing, Remote Connections - Can't VPN using WIFI please help!
Archived from groups: comp.dcom.vpn (More info?)
Hi,
At home I am behind a Lynksys Router, 802.11b. I am trying to use a Symantec
VPN client to connect to the network at my office and I'd like to be able to
use my WIFI but I can't get it to work.
I am able to use the router/VPN client combination to connect if I use
ethernet instead of WIFI. So there is something about the Symantec
client/WIFI combination that is causing a problem. When I compare the WIFI
vs Ethernet connect log files, they are identical up to the where I get the
error:
"400 Symantec Enterprise VPN Client Error: Communications with the ISAKMP
daemon failed."
Below is the complete log for the WIFI attempt.
Any help greatly appreciated. TIA
Jul 03 11:19:12.799 esquire kernel: 120 AXTVPN Info: Raptor VPN Device
Driver V1.2.10
Jul 03 11:19:12.849 esquire kernel: 120 AXTVPN Info: Processor Count: 1.
Jul 03 11:19:12.899 esquire kernel: 301 Internal warning: TCP session
[state: 2, inactive for 44 seconds] between XXX.XX.XXX.XXX/80 and
192.168.1.104/1095 timed out due to inactivity
[state: 2, inactive for 79 seconds] between XXX.XX.XXX.XXX/80 and
192.168.1.104/1170 timed out due to inactivity
Jul 03 11:19:12.909 esquire kernel: 301 Internal warning: TCP session
[state: 2, inactive for 64 seconds] between XXX.XX.XXX.XXX/80 and
192.168.1.104/1169 timed out due to inactivity
Jul 03 11:19:12.939 esquire emroute[3168]: 100 Info: The Symantec Enterprise
VPN Client Routing Daemon is starting.
Jul 03 11:19:13.390 esquire vpn: 401 Internal error: can't set interface
parameters for IP address 192.168.1.104
Jul 03 11:19:13.390 esquire vpn: 343 Interfaces Warning: The interface
192.168.1.104 was configured, but was not found on the firewall.
Jul 03 11:19:42.452 esquire emapi[4036]: 100 Symantec Enterprise VPN Client
Info: Entering EMAPI initial wait state.
Jul 03 11:19:42.512 esquire vpnd[3816]: 117 Daemon starting
Jul 03 11:19:42.542 esquire vpn: 401 Internal error: can't set interface
Jul 03 11:19:42.542 esquire vpn: 343 Interfaces Warning: The interface
Jul 03 11:19:42.562 esquire isakmpd[3812]: 117 isakmpd Info: Daemon starting
Jul 03 11:19:42.622 esquire isakmpd[3812]: 120 isakmpd Info: Not waiting for
Mobile
Jul 03 11:19:43.623 esquire isakmpd[3812]: 120 isakmpd Info: Reloading
tunnels to vpnd with 3 sec wait.
Jul 03 11:19:43.633 esquire isakmpd[3812]: 120 isakmpd Info: Reloading
tunnels to RaptorMobile with 3 sec wait.
Jul 03 11:19:44.625 esquire isakmpd[3812]: 120 isakmpd Info: Cannot find
entrust config file C:\Program Files\Symantec\VPNClient\entrust.cf. Will use
default configuration.
Jul 03 11:19:44.975 esquire isakmpd[3812]: 120 isakmpd Info: IKMPLogin:
Switched to lite mode, cannot access CA directory
Jul 03 11:19:44.975 esquire isakmpd[3812]: 120 isakmpd Info: Try to turn off
crl validation...
Jul 03 11:19:44.985 esquire isakmpd[3812]: 120 isakmpd Info: Successfully
logged into the ISAKMP engine with a default profile which has no
Certificate support
Jul 03 11:19:44.985 esquire isakmpd[3812]: 120 isakmpd Info: Reconfiguring
Isakmp tunnels
Jul 03 11:19:44.995 esquire emapi[4036]: 100 Symantec Enterprise VPN Client
Info: Continue operation.
Jul 03 11:19:44.995 esquire isakmpd[3812]: 120 isakmpd Info: Reloading
tunnels to RaptorMobile with 15 sec wait.
Jul 03 11:19:49.241 esquire emapi[4036]: 100 nsetup Trace: Session
Notification enabled.
Jul 03 11:19:49.492 esquire isakmpd[3812]: 120 isakmpd Info: Reconfiguring
Isakmp tunnels
Jul 03 11:19:49.542 esquire emapi[4036]: 100 nsetup Trace: Connecting
security gateway XXX.XX.XXX.XXX
Jul 03 11:19:49.552 esquire emapi[4036]: 100 nsetup Trace: Retrieving
configuration for gateway XXX.XX.XXX.XXX
Jul 03 11:19:50.093 esquire isakmpd[3812]: 120 isakmpd Info: Initiator,
Established ISAKMP SA (Lsg=192.168.1.104, Rsg=XXX.XX.XXX.XXX),
[tunTemplate=Universal]
Jul 03 11:19:51.314 esquire emapi[4036]: 100 Symantec Enterprise VPN Client
Info: Downloaded secure tunnel (10.1.0.0/255.255.0.0).
Info: Downloaded secure tunnel (10.2.100.0/255.255.255.0).
Jul 03 11:19:51.324 esquire emapi[4036]: 100 Symantec Enterprise VPN Client
Info: Downloaded secure tunnel (10.10.210.0/255.255.255.0).
Jul 03 11:19:51.334 esquire emapi[4036]: 100 Symantec Enterprise VPN Client
Info: Downloaded secure tunnel (10.32.0.0/255.255.0.0).
Jul 03 11:20:23.491 esquire emapi[4036]: 400 Symantec Enterprise VPN Client
Error: Communications with the ISAKMP daemon failed.
Jul 03 11:20:24.792 esquire emapi[4036]: 100 nsetup Trace: Error retrieving
information. Terminating connect operation to gateway XXX.XX.XXX.XXX
Sponsored Links
Did you install the WiFi card after you installed the VPN client?
The VPN client will bind to any present network adapters during
installation. If you install a network adapter post-install, the
binding does not take place. The VPN client will appear to be
connecting, but isn't able to complete and you get the message about
"isakmp" and then it disconnects.
Suggestion: Reinstall the VPN client with the wireless adapter
present.
Reply to Anonymous
Tom's Hardware > Forum > General Networking > VPN, VoIP, Video Conferencing, Remote Connections > Can't VPN using WIFI please help!
There are 1177 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
