How do you change the fluid color? are you able to use food color? is it just like water and is made to go in food and to jsut change the color of food basically like dye as in the same dye they use to color anitfreeze..cause they only give you a little bottle and once its mixed in with water and toped up its very diluted in color. was wondering how to strengthen it for a good look.
